Thread: IPOD Hookup
    Junior Member dgiordano's Avatar
    Florida
    RED
    2002 ws6 TA
    IPOD Hookup
    Just wondering if anyone has hooked up a IPOD to a late model Monsoon system? Can you hook up through the multi cd controller plug? it's a 2002 Pontiac WS6. would be great if you could use the steering wheel controls for changing tracks.
    thanks
    Member 02WS6dream's Avatar
    Jun 2006
    Charlotte, NC
    2001 Trans Am WS6
    done it in gf's and gf's sister car using in-line antenna modulator. Instead of transmitting over air to fm station, you actually mount a unit, powered, behind dash that plugs in line with fm antenna and has stereo head phone jack that plugs to ipod/any mp3 player. When unit is switched on, mp3 player is played through 1 of 2 choices of fm station--hard wired; no interference. when switched off, normal fm radio is recieved. car Fm antenna plugs into unit, which also has wire with stereo plug running from it to player, then unit plugs into stock radio fm antenna input. steering wheel controls have no effect on IPOD, but cost effective *$40* high sound quality, easy way to integrate
    Florida
    RED
    2002 ws6 TA
    Thanks for the response, I do know about this way to hooking it up. My question is about the cd changer plug I found a web site that sells a plug that they say works with the monsoon system and it hooks into the cd changer plug. CD quality hookup. I was just seeing if anyone has tried it.
    http://www.installer.com/ipod/index.php
    They have different ones and I am not sure the unit to get, I don't mind spending $150.00 if I can get a direct connection ans power to my Ipod.
    Florida
    RED
    2002 ws6 TA
    Junior Member lloydb3's Avatar
    Aug 2008
    Philly
    2002 Camaro Z28
    Check out icelink, charges ipod and is hardwired for sound directly to car
  1. 2000 Z/28 stock stereo - possible iPod hookup?
    By Phil's camaro in forum Stereo and Electronics
    Last Post: 10-23-2009, 04:12 AM
  2. I need a hookup - .dwg to .pdf
    Last Post: 01-30-2008, 07:33 PM
  3. iPod Hookup
    By lonemtnman in forum GTO
    Last Post: 03-02-2007, 06:03 PM
  4. Direct Ipod hookup to stock head unit ...
    By bjoneill98 in forum Stereo and Electronics
    Last Post: 03-28-2006, 09:45 AM
