Results 1 to 14 of 14
    Member Goldcuffs's Avatar
    Aug 2008
    Florida
    2000 Trans Am
    Replacing fuel pump
    Hey guys, I have to replace the fuel pump in my car (2000 T/A) and I really DON'T want to pull the tank. Has anyone tried making an access panel? If so, where? (exactly) I know in the hatch area.
    Ontario, Canada
    yellow
    02 Collector Trans Am
    there is a good write up on this on ls1tech.com search their formums for it. U can also buy trapt doors on ebay for about 30 bks and it comes with instructions. Personally, I would just remove the tank. I know its a big job, but at least u dont have to start hacking your bird.
    Feb 2006
    2002 WS6
    Ditto on the anti hack work. Cutting the metal is a good way to introduce rust.
    Aug 2008
    Florida
    2000 Trans Am
    ya shit, your probably right. It will be a pain but I guess it will be right when it's done.
    What's everyone using for a good pump. GM wants $625.00
    Feb 2006
    2002 WS6
    Most here buy the Walbro kit, not sure on cost, but I bet its probably half the price.
    Aug 2008
    Florida
    2000 Trans Am
    Quote Originally Posted by Orcus79 View Post
    Is it a stock replacement? (module style) Thats all I'm looking for.
    WA
    BLACK
    1999 T/A FIREHAWK
    Thumbs up
    Go to LS1Speed.com and get the stock fuel replacement pump, I just replaced mine 3 weeks ago and I used the trunk cut method, took me 1.5 hrs and instructions are easy to read.
    Aug 2008
    Florida
    2000 Trans Am
    Where did you get the instructions to do the cut method or did it come with the pump?
    tattoo artist,esquire sic2001's Avatar
    Huntington Beach, California
    navy blue metallic
    2001 trans am
    I cut the access as well, I went with a racetronix kit,took a couple hrs. Heres the link I used
    http://www.gonicd.com/intankinstall/...mpinstall.html
    GMPP LS6 crate motor,racetronix,Wilwood 6 piston,HID's,200mph speedo,full dynomat, GY F1's,17" Y2K, Alpine audio upgrade,3" ele cutout, LT's, catted-Y, full suspension
    Aug 2008
    Florida
    2000 Trans Am
    Alright, thanks guys, at least now I have a better idea and some different ideas.
    I would pull the tank and use a racetronix kit from harris speed works. Save yourself a bunch of money and pulling the tank really isn't that hard to do. Taking the exhaust off is the biggest pain in the ass out of all of it. You have a rubber fill neck so yours is easier than my 98 which has the metal neck.
    Member jamessr's Avatar
    Newport News, VA
    2000 Trans AM
    I dunno, I guess to each their own, I'd more than likely cut an access panel.
    Aug 2008
    Florida
    2000 Trans Am
    I'm probably going to cut a hole. It pays 4.2 hrs with no add time and that sounds like a pain in the ass to me. I live in Florida so rust shouldn't be an issue if I seal it back up right.
    WA
    BLACK
    1999 T/A FIREHAWK
    I took me only 2 hrs, I cut the hole and then i sealed it with JB weld....it worked and the total price for replacement was $170 for everything...
    Good Luck
  1. Replacing water pump
    By 12secws6 in forum External Engine
    Last Post: 10-04-2008, 02:02 PM
  2. Replacing water pump on 78 Camaro LT
    By camaroblue in forum Classic Muscle
    Last Post: 09-16-2008, 04:48 PM
  3. replacing the fuel pump
    By redbird98 in forum General Help
    Last Post: 08-02-2006, 08:20 PM
  4. Replacing AIR pump:
    By MarkuzLS1 in forum External Engine
    Last Post: 06-20-2006, 04:20 AM
