09-11-2008, 05:33 PM #1Member
- Jul 2007
- Allen, TX
Red- 2001 Trans Am
How to tell if you need general maintenance
Ok, so my car is getting up there in age and mileage so I want to be responsible and keep up with the maintenance. I'm not a mechanic by any means unfortunately so I need some advice. How can you tell if you need new spark plugs and wires? Also, how can you tell if you need new shocks and springs? And finally, the type of tranny fluid to use is Dexron III ATF correct?
09-11-2008, 09:50 PM #2
Yes Dexron is the the stuff to use, the number really doesn't matter aslong as its Dexron.
As for plugs and wire thats kinda guess work with out pulling them out and having a look?
Are you the first owner? how many miles? How well has regular maintenance been done? That all plays a factor. How well is the car running?
09-12-2008, 06:03 AM #3
If you've got a manual transmission, you might want to invest in a nice synthetic transmission fluid (like B&M Trick Shift). Other than that, I'd recommend just following the normal maintenance schedule in the manual.
09-12-2008, 06:07 AM #4
09-12-2008, 08:16 PM #5Member
- Jul 2007
- Allen, TX
Red- 2001 Trans Am
i'm the second owner and its got 66,000 miles. its in pretty good condition but just doesnt feel as good as it probably should plus the fact that i'm just paranoid. I heard synthetic trans fluid isnt good, so i've been planning on using the dexron all along. anyone got any tips on seeing if you should replace shocks and springs?
09-13-2008, 05:11 AM #6Member
- Nov 2005
- allenhurst GA
onyx black- 1999 formula firebird
when was the last time you put the car up on a lift and greased anything???? nobody ever does that anymore...ever..then they wonder why shit squeaks, rattles, and dry rotts...
09-13-2008, 07:11 AM #7
i dout you need shocks and springs all ready thay last a long time unless the last owner wint off road all the time. but you can always up grade if you want. if you do talk to sam at stranoparts.com and look into his springs
General Routine Maintenance / Service Intervals
By 35th-ANV-SS in forum General HelpReplies: 38Last Post: 02-03-2013, 03:26 AM -
General maintenance while at valve covers
By TokerM in forum General HelpReplies: 16Last Post: 10-12-2010, 06:14 PM -
maintenance
By kthmc33 in forum Firebird / WS6Replies: 8Last Post: 07-14-2008, 02:09 PM -
"General Petraeus or General Betray Us"....discusting
By cam02ss in forum Political / Debate ForumReplies: 19Last Post: 09-26-2007, 03:50 PM -
General maintenance
By xAgentP in forum General HelpReplies: 3Last Post: 09-05-2006, 07:41 PM
