Results 1 to 11 of 11
Thread: Wet floorboard
    Member chevyss1234's Avatar
    Feb 2007
    Clemson SC
    Wet floorboard
    okay i i'm not sure where it's comin from but its from somewhere in the front of the car, maybe the cowl panel... there's always a damp spot in the front of the car underneath the pedals, or right behind them. i pulled up the carpet to find out what it mgiht be, because there's no leading trail as to where it's coming from. Are there any common spots that leak near the firewall? Anyone had a similar problem?
    Thanks
    Member Goldcuffs's Avatar
    Aug 2008
    Florida
    2000 Trans Am
    Does it feel like water or engine fluid? (oil,antifreeze,brake fluid)
    Feb 2007
    Clemson SC
    definitly water, plus the wet spot shows up every time it rains.
    Member axxdet's Avatar
    May 2008
    MI
    pewter
    2002 firehawk
    heater core ....?
    Feb 2006
    2002 WS6
    Most likely the seal around the front windshield has let go. probably down in one of the corners.
    i'm not sure about our cars... but on a lot of cars there is a catch pan for the AC and when you go arond corners, accelerate of brake hard the water comes out of the pan and makes it's way to the floor...
    Feb 2006
    2002 WS6
    That would all be on the passenger side of the car, not the drivers as was said. The only way for water to get there would be a leak int he seal of the front windshield, a leak in the cowl from some poorly done mod or shody repair work. Even possibly a leak in the door seal.
    May 2008
    MI
    pewter
    2002 firehawk
    oh I see I didn't catch that part....
    Quote Originally Posted by Orcus79 View Post
    doh!!! didn't see that it was on the drivers side...
    could also be fromthe T-tops not sealing all the way also.. the water can run down inside the piller to teh floor...
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Have someone with a hose water down the car while you are inside and see if you can locate the leak.
    Feb 2007
    Clemson SC
    word i guess i'll be doin that this weekend i'm guessin it's the cowl panel somwhere
    Thanks for the help guys i'll keep u posted. let me know of any more ideas
  1. Help: Exhaust Hitting the Floorboard
    By 90ARAPAJ in forum Firebird / WS6
    Last Post: 09-16-2011, 04:17 AM
  2. Clunk under drivers floorboard...
    By oneclean98z in forum External Engine
    Last Post: 02-20-2008, 09:19 PM
  3. Exhaust hitting floorboard??
    By danman in forum Firebird / WS6
    Last Post: 08-13-2006, 05:09 PM
  4. Exhaust hitting floorboard???
    By danman in forum General Help
    Last Post: 06-30-2006, 10:14 PM
  5. Air Condition blows out floorboard.
    By nerd4life in forum General Help
    Last Post: 01-14-2006, 06:03 PM
