Results 1 to 2 of 2
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Exclamation 327 Small Block Chevy - The Misfit
    Check out this 327 small block Chevy Engine with a 142 series Weiand supercharger.If you recall our three-for-all engine build and test, "Three-Way Mousefest" (Aug. '08), we built and tested three radically different mills (327ci, 355ci, and 383ci) and showcased what could be done with today's modern off-the-shelf parts. Our Misfit 327 churned out an impressive 391 hp on pump juice for around $4,000. Now it's time to add some zip to the little mule. To recap our combo, we utilized a cast crank and rods, flat-top hypereutectic pistons, a hydraulic flat tappet cam, a Dart Iron Eagle top-end kit, and a 2-inch Wilson manifold spacer-nothing crazy by any means.
    Photo Gallery: 327 Small Block Chevy - Chevy High Performance Magazine
    More...
    Army Dude robcas47's Avatar
    Ft. Rucker Area, Lower AL
    01 TA / 06 Duc 749D
    thank you for this. i have been wondering what kind of power a 327 with a blower can make. the best part was that all this was acomplished at a very affordable price. my only question is if stock heads were used or aftermarket? i pulled my 327 from my project and was thinking about replacing it but if i can easily make this kind of power for about 2k then it's worth keeping. thanks again Ed
  1. Chevy Small-Block, Big-Block & Transmission Buildi
    Last Post: 11-20-2009, 01:50 PM
  2. Small-Block Chevy Build - Cheap 350
    Last Post: 04-17-2009, 10:40 AM
  3. Small Block Chevy - The Last Small-Block Chevy Str
    Last Post: 11-17-2008, 10:40 AM
  4. Small Block Chevy Buildups - Three-Way Mousefest
    Last Post: 08-01-2008, 09:20 PM
  5. How to Rebuild Small-Block Chevy LT1-LT4 Engines
    By Musclefan21 in forum Parts For Sale / Trade
    Last Post: 11-23-2007, 05:09 PM
