Results 1 to 18 of 18
09-08-2008, 02:13 PM #1
Radiator cracked, help replacing?
I got home today to see that coolant was spilling out of the car onto the ground and found that i had a leak in the top of my radiator. I have no idea how to replace, except to disconnect everything from it pull it and replace it.... i know its not that simple so can anyone else help me out as how to do it or should i let someone else do it?
Its a 95 Camaro Z-28
09-08-2008, 02:32 PM #2
Well you can look at the cam install instructions at LS1 How to, I know yours is LT1 but should give you some idea what's goin on. Skip evrything cept the radiator removal. Lol.
http://ls1howto.com/index.php?article=23
09-08-2008, 03:28 PM #3
So i dont have to take the front end of the car off or anything like that?
Oh yeah is there anything i should be careful not to do?Last edited by 95camaroZNC; 09-08-2008 at 03:46 PM.
09-08-2008, 04:12 PM #4
Don't get the opti wet. Thats bad JuJu. no The front clip doesn't have to come off. Dissconect the battery. Drain the system, remove and hoses and sensors attached to the rad, remove the air box, unplug the fans, unbolt and remove the upper support and voila. Thats the shot version of it but thems the basics.
09-08-2008, 04:35 PM #5
So the link you all sent me pretty much covers everything, Wish me luck im going to try friday when they get the radiator in.
09-09-2008, 02:07 PM #6
You all suck, this was kinda difficult. I did part of it and ........ ok i guess it wasnt that hard if id known and done it before. Anyway how do i get the hoses off in a easy way, the clamps are difficult to get off.....
09-09-2008, 02:12 PM #7
H good pair of plyers if they are a spring clap, You would ahveto wiggle them and trust them a bit. Same if they are a hose clamp type. The hoses, well get a flat blade screwdriver under there and try. They will be stuck and need some force to get free.
This would be a good time to replace em if they are old, So you could cut and peel them as well.
09-09-2008, 02:42 PM #8
I was kidding...... about the sucking.... i mean if you cant contribute anything why do that.
Anyway thanks for the advice on the clamps thats the only thing ive had a problem with so far, when i do get done ill try and do a write up for a LT1 radiator since im doing it for my car club forum.
Is there anything else i need to know, oh yeah and will the condenser sit up in the front where it is or do i need to take it out too? It looks like it just detaches from the radiator and lifts up and out of the slots in it. Anyway thanks for the help so far im gona try and finish up friday since i have the day off work. The most annoying thing so far has been that the idiot who had it before me put the bolt for it upside down....
Anyway
you guys and thanks for the help so far.
09-09-2008, 02:49 PM #9
The condenser should just sit there if you are careful with it. Shouldn't need to remove it, but I have yet to remove a rad on one of those cars.
09-09-2008, 04:36 PM #10
Oh yeah, is there anything that can go wrong sensor wise in the car from unplugging all the stuff that was in the air intake?
09-09-2008, 05:57 PM #11
As long as you are careful, There shouldn't be. Make sure the battery is disconnected. Be sure that they all get fully connected when it all goes together.
09-11-2008, 11:48 AM #12
melt a zip tie on where its leaking from with a torch, Its what we did with our race car...
09-12-2008, 05:56 PM #13
Soo i got in all installed and now the cars over heating, i purged all the air out of the lines and have figured out its because the Fans arent running at all, the fans worked fine before but now they are not. Also with all the stuff i removed from the old radiator i also removed a small green box and out it on the new radiator, my friend removed it rather harshly and everything ive read makes no mention of it, not even the haynes manual i broke down and bought today.
I welcome any suggestions you all have, id really like to get the car fixed as fast as i possibly can, i know i didnt mess up the thermastat as well becasue it says that if the top pipe is hot then its circulating the water, which it is, I really think its just the fan.
I tryed to figure it out for 8 hrs today and no luck....... im about to
and have someone else fix it but i really want to finish it myself.
09-13-2008, 10:50 AM #14
You would know right quick if the fans were working or not. Backtrace your steps starting at the fans and working backwards. Make sure everything is plugged in correctly and is nice and tight. The connection can look like they are plugged in but not be fully seated.
09-13-2008, 11:09 AM #15
Wrote ya on fayetteville...
09-13-2008, 03:30 PM #16
They are connected. I double checked the connectors.
The fans did work before i started the project, We just tryed what you said and the fans ran while the car was sitting still with the AC one of them was running really strong and one of them felt kind of weak. My dad had me turn the AC off and drive it around a few times, sure enough the car started to over heat again, when we parked the car we tryed turning the AC back on to see if the fans would kick on, they didnt come back on when i turned the AC back on. Any ideas?
We have decided what ever part is responsible for turning the fans on and off, ISNT turning the fans on and off.....Last edited by 95camaroZNC; 09-13-2008 at 03:44 PM.
09-14-2008, 10:54 AM #17
Try swaping out the relay.
09-16-2008, 09:42 PM #18
I gave up and took it to my mechanic ill be sure to post what the problem is when he figures it out, he looked at it today and couldnt figure it out so i guess i dont feel so bad about it. Thanks for all your help though guys i really cant thank you enough!
Help: Boiling sound at radiator, radiator cap blowin off
By lanprat in forum External EngineReplies: 7Last Post: 08-05-2012, 04:29 PM -
Question: Cracked Radiator... any non plastic replacement suggestions?
By manibot in forum External EngineReplies: 2Last Post: 08-26-2011, 06:27 PM -
Radiator cracked
By zeetwentyeight in forum General HelpReplies: 8Last Post: 11-19-2009, 03:14 PM -
Help - cracked radiator
By MSTZ TA in forum External EngineReplies: 22Last Post: 07-13-2009, 03:47 PM -
Project Shark Attack C3 Corvette Radiator Install - Radiator Fallout
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 04-03-2007, 09:20 AM
