Results 1 to 15 of 15
    Junior Member BKDZ28's Avatar
    Aug 2008
    Boston, Mass
    Maroon
    2000 Z28 LS6, LT,ORY
    Just bought 2000 Z28 A4 84k looking for Mod Advice
    Hey everyone I'm new to this site, My name is Bryan I live just outside of Boston! i purchase a 2000 Z28 with 84k A4 for $5000 cash stole it! I'm looking for some help with modification advice etc... I have already done most of the free mods egr, throttle bypass, slp cold air, cat back. What should i do next>??? the car has 2.73 gears which suck!!! i was also thinking of a programmer Diablo hypertech or custom tume etc... LS6 intake maybe over the winter, does porting the stock throttle body or MAF do anything or should i buy a larger one? please give me any advice to what mods in order would be best. thanks for the help!!! Bryan feel free to send me a message if you live in the area also
    Member 666ws6's Avatar
    Greenville, SC
    2000 Trans Am Ws6 #2946
    My thoughts... Lower it, and get a TC. Then cam it (dyno tune) and 3.73s.
    Feb 2006
    2002 WS6
    Free mods, and tranny cooler to start off, Your trans will thank you.
    Toledo, Ohio
    1998 Camaro
    Good job with the free mods, Bryan. And welcome to the site. Congrats on stealing that Z28, too. You are on the right track. I would avoid MAF sensors or Throttle Bodies for now, low HP/dollar return. Do not modify your factory MAF, I made the same mistake and ended up buying a new OEM MAF. I would recommend you focus on the gears and tranny right now. Go with a 3.73 and upgrade to a higher stall converter. While you are in there, run an additional cooler, as Orcus79 suggested. I've seen A4 guys pick up a half second on the track with gears and stall. No more power, but better use of what you already have. Since you're changing gears, you will need either a custom tune or a programmer. Diablo makes a great one for a hand held. THe best for you is a custom tune, however, that can be difficult unless you have the convenience of a good LSX guy with a Dyno close to where you live. If you haven't done headers, LS1 engines like long tubes, as well. Happy modding, and don't forget, spending money saves the economy.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Get a stall, cooler, Long tubes, ls6 intake, custom tune, subframe connectors, a 12 bolt(dont waste money on the stock rear end) and that should help a bit
    Party Time, Excellent... Kingc8r's Avatar
    Jan 2008
    Bay Area, California
    2000 Z-28
    Best advice yet. If I could do it over I would have purchased a stall first
    Aug 2008
    Boston, Mass
    Maroon
    Thanks for all the help so far! I hope to take it to the track next week to get a base line on the car. Thank again Bryan
    Beaver Dam KY
    79 T/A -91 Firebird
    Awesome! Post up all the info when you get time!
    allenhurst GA
    onyx black
    1999 formula firebird
    welcome man, friggin awesome deal on the Z....i dont have an A4 but after your stall/gears combo if that is what youa re doing , get some exhaust...DO NOT BUY SLP headers/ ORY....especially if you want to get rid of the 4x4 look...just a word of advie from somebody who cant afford to replace his exhaust and speedbumps LOVE to HUG ME...
    Aug 2008
    Boston, Mass
    Maroon
    what are a good set of Headers? A set thats not going to break the bank either? also Y pipe etc... Thanks for the info
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    pacesetters are great, also look at the for sale section here and on ls1 tech for a used set, you can usually get a pretty damn good deal. get some gears to go with it and you can look at low 13's high 12's-tune of course get a custom tune.
    Aug 2008
    Boston, Mass
    Maroon
    Yeah that's about where i'm lookin to be. i want a reliable street car that will hit the high 12's. I'm planning on 3.73 gears this winter and also a ls6 intake and maybe some suspension equ to put power to the ground and my first tune come spring. Did you change you Diff when you did your gears and is it advisible. also suspension mods Im planning on subframe connectors i have T-tops what about lower trailing arms, adjustable pan hard rod and torque arm ??? are they worth it??? Thanks for all the help
    Greenville, SC
    worth it
    You shouldn't need to change the differential itself, just the gears. Add a girdle though to help give strength and the ease of a drain plug.
    Plan out your work, don't get too excited that you take on or spend too much. Once I got a TC, I had trouble keeping the rear planted. A lot of wheel hop and terrible 60 ft. LCAs, PHR and torque arm fixed that nicely.
    Aug 2008
    Boston, Mass
    Maroon
    Thanks for the advice. I agree , I want to get the power to the ground, what good is it if you don't! what brand of torque arm and panhard rods etc... would you recomended
    Greenville, SC
    There's a lot out there and I did the research years ago, that's part of the fun! There is much more now than 6 years ago.
    I got boxed LCAs with the welded on relocation brkts. They really really helped. I bought Hotchkis for LCAs and PHR. Torque arm is BMR adjustable. Look around and see what you want to spend where. Unless you really plan huge hp, anything you get will be a huge gain over stock.
  1. just bought a 2000 corvette
    By dian in forum Almost Anything Goes
    Last Post: 07-21-2015, 03:05 PM
  2. Just bought an 02 Z28, need advice on title issues
    By pscmj84 in forum Almost Anything Goes
    Last Post: 11-16-2007, 01:58 PM
  3. Just bought LT's.... Need advice on cutout
    By Whiteboycntdnce in forum External Engine
    Last Post: 11-16-2007, 11:20 AM
  4. Just bought a 2000 Z/28
    By GeArBaNgEr56 in forum Camaro / SS
    Last Post: 03-01-2006, 01:14 PM
