Results 1 to 16 of 16
Thread: Painting Tips
    Angry Painting Tips
    I'm having a major bitch of a time painting some stuff and I'm this close }{ to just buying new products and having them professionaly shot.
    I wanted to permenatly gloss up a few items in the engine; the intake lid and base that it sits on as well as the TCS unit's cover.
    I washed them all and sprayed with modeling paint-it crinkled up and so i figured "well car paint might work better"
    So i sanded them and shot with Duplicolor Universal Black. It did an orange peely kinda thing, so i sanded them and shot them again. More orange peel. Sanded again and now have huge voids that have ripped away from the pieces, OR i have ugly runny/rivery looking junk. Needless to say, all the sanding and respraying is pissing me off. Is this all because I didn't primer? Do i have any chance to save these pieces? Should i strip the paint and start over, buy new ones and have them done?
    Note to current/future/past customers: Make no mistake, i'm not the guy who did/is/will be painting anything that you order-production is directed by SandmanWS7 who knows how to professionally finish a piece off.
    lmpounded SandmanWs7's Avatar
    Dallas, Texas
    2007 CTS-V
    Yes always primer and sand that will give you a smooth finish.
    Dallas, Texas
    2007 CTS-V
    the orange peel is from the intake itself, they are not smooth. put enough primer and sand till it is smooth.....
    or ship it to me and I'll do it.
    you mean the deck lid isn't smooth-i'm not even to the intake yet
    so should i strip off what i've got so far?
    Dallas, Texas
    2007 CTS-V
    yes
    Dallas, Texas
    2007 CTS-V
    ALso see if the autoparts store sell an adhesive spray. I know here we have an adhesive that we can shoot under base coats to make sure the paint/primer will stick to it. And I am not talking bout 3M adhesive. Its a special adhesive used for painting.
    I've heard of that...so does that go on before or after primer?
    Dallas, Texas
    2007 CTS-V
    before
    Member Mike's TA's Avatar
    Austin, TX
    99 Trans Am(sold)
    Just had to comment. That made me laugh so hard. Great use of Smilies!!!!
    San Diego ca
    "Arrest Me Red"
    2001 trans am
    im not a painter buy any means and want to paint a bunch of stuff on my ta to but when i have done interer parts on my last show car i used and had good luck with rc car body paint
    Senior Member GULLETT17's Avatar
    Muncie, IN
    00 TA PWTR, 98 VertTA NBM
    80 TA BLK, 80 Formula NBM
    plastic stuff always seems like a pain to me. . . always remember to use paint prep/cleaner. if not, at least use reducer to clean all parts.. do this many times to make sure any oils/contaminents(sp?) are gone. this is what most likely causes the paint to seperate or fish eye (this is when the paint is orange peeling to the extreme, normal orange peel is usually just do to the spray of your gun). next important is the primer. make sure it is a primer for plastic and/or is flexible primer. hope this helps man!
    allenhurst GA
    onyx black
    1999 formula firebird
    sandman pm me with what you charge to paint stuff...i may have some work...
    Junior Member DevilDougWS6's Avatar
    Toms River, NJ
    2000 Pontiac T/A WS6
    sand starting with 400 grit, then do 600, then 800, then 1500, CLEAN, then spray with adhesion promoter, then primer lightly, sand with 1500 grit, primer more, sand again, primer more, sand again, clean, spray with color lightly, wait, repeat, wait, repeat, spray clear, etc etc etc.
    Muncie, IN
    Quote Originally Posted by DevilDougWS6 View Post
    many thin coats will prevent running. . . however clear you will need to spray enough to get a smooth coat, too lightly will give a rough texture and more extreme orange peel
    Member Piranhaz's Avatar
    Aug 2008
    Minnesota
    1999 Trans Am M6
    A good piece of advice that most seem to miss is to clean the part with wax and grease remover thoroughly before doing any prep work at all, that includes sanding. We had some guys that worked at the old shop that would sand the part before cleaning it up and basically it spreads the contaminants on/in the part and they would get fish-eyes all the time. Just my .02
    Muncie, IN
    Quote Originally Posted by Piranhaz View Post
  1. Need some painting tips.
    By Blksnshn in forum Showcar and Detailing
    Last Post: 06-25-2011, 08:36 PM
  2. Tips on painting LS6 Intake Manifold?
    By GottaHaveLS1 in forum Appearance Section
    Last Post: 05-08-2011, 09:37 PM
  3. Painting With Waterborn Paint - Painting With Wate
    Last Post: 06-17-2010, 03:00 PM
  4. Retro Stripe Painting - Painting Homage
    Last Post: 06-17-2009, 11:10 PM
  5. painting calipers-tips
    By blue02Z in forum Appearance Section
    Last Post: 10-02-2007, 10:28 AM
