Thread: M6 Tranny Lubricant
09-04-2008, 05:54 AM #1
M6 Tranny Lubricant
I own a 2000 Trans Am m6 WS6, and was wanting to switch over to royal purple products. Would i use "Max Gear 75W-90" or "Synchromax"?
Also...
what would i use for rear differential?
09-04-2008, 06:52 AM #2Member
- Feb 2008
- NEW JERSEY
PEWTER- 2001 TRANS AM WS6
Stay away from royal purple stuff its not worth the money and its alot of hype atf 3 goes in the trans 75-90w synthetic gear oil for the rear
09-04-2008, 07:30 AM #3Detailing + Design
- Pittsburgh, PA
NO NO NO NO NO NO NO NO NO
just get some traditional DEX III ATF [i belive that's an older lubricant, so look for verbage like "replaces DEX III" or "alternative for transmissions requiring DEX III"
PS, synchromax will kill your sych's as they are made from Carbon, not brass like the 01+ models.
09-04-2008, 08:53 AM #4
09-04-2008, 06:05 PM #5
09-04-2008, 06:38 PM #6
From the factory there is a tag right on the side of the transmission that reads "Use Dexron III ATF Only". So thats a yes.
There is a difference in the synchros through the years, later years apparently had better blocker rings and synchros (early blocker rings were "paper"), but all the T56's use GM Dexron III Automatic trans fluid.
T56 Rebuilds reccommends Mobil 1 ATF, which is what I run in my transmission, its good stuff. I've also heard that Amsoil Synthetic ATF is very good as well, haven't tried it though.
09-05-2008, 04:31 AM #7
Amsoil ATF Fluid
AMSOIL ATF is recommended for many applications. One of which is transmissions requiring GM DEXRON® II, III & VI specified fluids.
Resists Oxidation and Thermal Degradation
AMSOIL ATF resists thermal and oxidative degradation better than conventional transmission fluids, protecting clutches, planetary gears, valves, pumps and seals from damaging sludge and varnish deposits. AMSOIL ATF helps prevent component overheating and ensures cooler, smoother transmission operation.
Amsoil Synthetic ATF Applications Guide pdf
Cold temperatures and ATF Fluid pdf
Amsoil Synthetic ATF link
CompSynLast edited by CompSyn; 09-05-2008 at 06:06 AM. Reason: Added Amsoil Technical Service Bulletin pdf files
09-05-2008, 04:53 AM #8
I have always used the Dex III ATF in mine. If you change it enough, that will be ok. I think I'm going to switch over the the Amsoil stuff next time though. Compsyn talked me into it!
2018 Tahoe - Silver - OEM
09-19-2008, 02:22 AM #9Awaiting Activation
- Jul 2007
- Midwest
black- 2002 Trans Am
Picking a lubricant
By Supersport0126 in forum DrivetrainReplies: 3Last Post: 03-15-2012, 05:13 PM -
Official Lubricant Sponsor for the 2010 Hot Rod Dr
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 07-22-2010, 04:20 PM -
Base Oils & Lubricant Performance (1 of 3)
By CompSyn in forum Internal EngineReplies: 2Last Post: 12-03-2008, 01:56 PM -
Does anyone have an Auto Tranny 4L60E tranny layin around thats in good shape?
By LT1RacerMan23 in forum Parts Wanted / TradeReplies: 5Last Post: 01-28-2008, 01:48 PM -
Engine Restorer and Lubricant Formula
By blk_jaws in forum Internal EngineReplies: 5Last Post: 01-10-2006, 12:47 PM
