Thread: 2002 SOM 35th Z28 Camaro
08-29-2008, 08:39 AM #1
This is just a FEELER for now to see how many bites I get and to see if anyone is actually interested in the car. First off its an 02 SOM Z28 35th Aniversary Edition Camaro w/about 75k. I bought this as a DD and have since turned it into a race car. The motor is all stock ci and internals. I have quite a bit of work done to the car and I will try my best to list everything eventhough I am sure I will forget some things.
Motor:
-Stock LS1
-Stg 2 stock casting heads ported by Mikey at Rapid
-g5x2 cam (232-240)
-918 springs on exhaust side and AFR springs intake side
-Hidden dry kit
-Fast 90mm intake/TB
-edelbrock (1-3/4", stepped to 1-7/8", 3-1/2" collector, mild steel)
-true dual exhaust (summit race mufflers)
-race mufflers, w/4 inch turn downs
-strange 12 bolt with 4.10's
-Coan th400 w/ transbrake
-B&M pro-stick composite sifter
-Raptor shift light
-PAF 10pt sportsman chromoly roll cage cert till 2010 or 11 I can't remember
-g-force quick release 5 point harness
-steel 3inch driveshaft
-2 tranny coolers
-Qa1 front 12 adjustable shocks
-strange adjustable rear shocks
-spohn Lower Control Arms - Adj. with Poly Bushings
-spohn Adj. Torque Arm - LS1 F-Body w/Long Tubes w/drive shaft loop
-spohn rear drag bar
-BMR Double adjustable panhard bar
-Black Crome prostars w/30inch slicks and skinnies
-QA1 drag springs up front with stock springs in the back
-Braille 6.6lb race battery
-door bars removed
-front and rear bumper supports removed
-both air bags removed
-Grant steering removable steering wheel
-FJO for the nitrous
-JAZ racing seat
-Car is mor or less completely gutted on the inside but looks gorgeous on the outside.
-I just ordered a VFN hood, it will be here in 4-5 weeks. Its the Mike Moran pin on hood. The stock hook will be included with the sale of this car. The car is in mint conidtion. It also has 5% tint all the way around. I will post pictures up either tonight or later on tomorrow.
-The times the car has run....well ALL MOTOR with 26inch slicks it went a 10.4 @126....I have a ton of slips I will have to find aswell. With a set of 28's and a 150 shot it went a 10.1 @127 with me slamming on the brakes, I ONLY SPRAYED IT IN 1ST GEAR! I pulled a 1.36 60' with the 28's.....The 30's that are on the car now have never seen the track. I am trying to make it to the track this weekend to see what it will do on the motor and to give it a full nitrous pass. I have no idea what the car will run with a full nitrous pass, but I am guessing somewhere in the 9.8-9.6 mark. I have weighed the car in the spring and with me in it "170lb" it weighed in at 3230.....but since then I have changed the battery and took some more weight out of the car. I am about to pull the door bars out and install a manual brake conversion kit, ABS delete, and line lock kit....
I know this isnt everything that is done to the car so feel free to ask me any questions. I am asking 15,000.
08-29-2008, 08:42 AM #2
Here are some vids of some 10.8 ALL MOTOR passes, and the one of me lifting the wheels is when I sprayed the 150 just in 1st gear and hit the brakes at the end....I think that was the 10.1 pass.
http://s25.photobucket.com/albums/c8...t=100_0404.flv
http://s25.photobucket.com/albums/c8...t=100_0383.flv
http://s25.photobucket.com/albums/c8...t=100_0389.flv
The pictures don't show the latest mods like battery and some other things, I will try and get more engine shots and I will try and get some interior shot today! This is what I have so far. Hope this helps! Anymore questions please ask!
08-31-2008, 09:29 AM #3
09-02-2008, 10:36 AM #4
This car also comes with a stock passenger side seat with 5pt race harness......so you can throw your woman in here and roll aswell.
09-02-2008, 02:16 PM #5
The price is OBO!
09-02-2008, 04:19 PM #6Member
- Jun 2007
- Baltimore, MD.
- iTrader
- 4 (100%)
Bright Red- 2000 Pontiac Trans Am WS6
Love the wheel's up shot Kevin!
Good Luck with the sale.
BTW, I have unlimited HPTuners for 2002 F body (amongst others).
I can raise rev limiter for you if need be...no charge.
That wheel's up video you were on the limiter pretty hard it sounded like.Last edited by rel3rd; 09-02-2008 at 04:21 PM.
2019 Silverado LT Z71 5.3, 8L90E
2000 Pontiac Trans Am WS6 6.0, 4L80E, 9" rear, TURBO...
9.32@147
09-02-2008, 06:21 PM #7
09-02-2008, 06:52 PM #8
For Sale: 35th Anniversary 2002 Z28 Camaro
By TheCamaro515 in forum Vehicles For Sale / TradeReplies: 3Last Post: 06-27-2011, 02:23 PM -
For Sale: 2002 SS Camaro (35th)
By aviationphotog in forum Vehicles For Sale / TradeReplies: 2Last Post: 03-15-2010, 11:42 AM -
For Sale: 2002 35th Ann SLP Camaro SS
By 2002ss in forum Vehicles For Sale / TradeReplies: 7Last Post: 01-28-2009, 12:33 PM -
2002 camaro z28 35th anv
By brandon0212 in forum Vehicles For Sale / TradeReplies: 5Last Post: 04-09-2006, 04:28 PM -
2002 35th Camaro
By MrHouse in forum Vehicles For Sale / TradeReplies: 1Last Post: 11-14-2005, 11:36 AM
