Results 1 to 20 of 29
    Aug 2006
    San Diego, CA
    1999 T/A
    5 grand to spend....mmmm
    Ok so what do I do with 5000 bucks. I allready have ms4 cam, double vavle springs, chromemoly pushrods, ls6 intake, lid, k&n air filter, tires, lt headers with td exhaust, and ngk tr55 irdium spark plugs with msd 8.5mm wires installed on my car. Not tuned though. I have a moser 9" rear with 4.11 gear ratio and full spool diff and textralia oz700 clutch waiting to be put on. What should I do with the 5 grand?
    Senior Member
    rochester,ny
    pewter
    2001 z28 lingenfelter 383
    Quote Originally Posted by B.A.N.A.T.A. View Post
    invest it ........i didnt read heads on there? stroke it?
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    youve done plenty to the car, do vegas for a week straight!
    youll have more memories from that week than the car will ever give you
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Carless blkSS98's Avatar
    Jan 2008
    Eastsound, WA
    Trick flow 515 h/c package and tune!
    Member stephen02ws6's Avatar
    Dalzell, Illinois
    red with black stripes
    2002 Trans Am WS6
    afr heads and built tranny that will cover the 5grand
    Member JAGUAR5822's Avatar
    San Antonio, TX
    2001 SLP SS Convertible
    Get a dyno tune, a big brake kit, and go for a couple track days
    i'll let you pay me $5,000.00 to have me make some passes @ englishtown this week end...
    Gainesville, VA
    I'd get some quality heads like Trick Flow or AFR, FAST intake, TB and a tune. Save the rest for a stroker short block down the road.
    You could sponsor wanted mods for my car
    Member blackls1ta's Avatar
    kittanning,pa
    2000 ws.6 m6
    Quote Originally Posted by stephen02ws6 View Post
    +2 afr heads milled and built tranny,and a wet kit 150 shot.
    Senior Member
    rochester,ny
    pewter
    Quote Originally Posted by nhraformula View Post
    im with this guy ...and bring back
    Veteran Blackbird WS6's Avatar
    van down by the river
    heads/tune/trans if you have a auto, if you have a m6 heads/ Suspension/ tune
    i missed the clutch part, heads/Suspension/tune
    Member wenn_du_weinst's Avatar
    Aug 2008
    South Dakota
    I would do all of the suspension /braces for the car and heads
    in my Trans Am
    2000 Trans Am WS6
    turbo that biatch! save up a bit more
    Aug 2006
    San Diego, CA
    1999 T/A
    What about Patriot Stage 3 heads. I could get them for 1050, with dual springs installed
    The specs are Combustion Chamber: 72cc
    Intake Runner: 227cc
    Exhaust Runner: 70cc
    Intake Valve: 2.08"
    Exhaust Valve: 1.60"
    Max. Valve Spring Lift: 0.650"
    Spring Pressure Closed: 135 lbs. @ 1.800"
    Spring Pressure Open: 375 lbs. @ 1.090"
    Retainer Material: Titanium
    Valve Seal Material: Viton
    Valve Guide Material: Manganese Bronze
    Valve Job: 5-angle
    i had a ?? if you put those heads with all your other mods will you need bigger Fuel Injectors
    Jesus died to save you! Killer_bluebird's Avatar
    North Olmsted, OH
    If you want heads that will clear that cam then Stage-1 set or Trickflows. I would do the Trickflow 215cc, 42# greentop injectors, a ported 92mm Fast and Tune then call it a day. That should put you close to 500 rwhp.
    Or you can take the engine out sell it for 3-4k then add the 5K and get a nice built LS2 402 or a 427 L92.
    Member LSx Heaven's Avatar
    amarillo, texas
    All colors
    1993-2002
    Stroke it, you will love that low end torque.
    2 SS's are better than 1 Jays00ss's Avatar
    Lathrop, Missouri
    NBM / Silver
    00 SS / 71 SS Elcamino
    save it for a down payment on the "New" Camaro
  1. Stock 2002 camaro ss looking to spend about 8 grand
    By Parsnips in forum General Help
    Last Post: 08-17-2011, 05:29 PM
  2. I'mmmm Baaadged...
    By kebie05 in forum Appearance Section
    Last Post: 01-31-2008, 10:48 AM
  3. 1975 Pontiac Grand Am - Grand Am Grand Slam
    Last Post: 12-03-2007, 06:30 PM
  4. MMmm Good!!
    By rbob93 in forum Almost Anything Goes
    Last Post: 08-05-2007, 03:03 PM
