Results 1 to 20 of 21
Thread: $1.99 Pennzoil Platinum
08-24-2008, 03:48 PM #1Grand Imperial Wizard
- Retired Outlaw Sum Bitch
On sale at all nationwide Checkers Auto Parts stores through Sept 13th.
08-24-2008, 03:53 PM #2
I'm waiting to put amsoil in this time i think.
08-24-2008, 03:58 PM #3Grand Imperial Wizard
Good man Dobie but all of us aren't rich like you.
08-24-2008, 04:02 PM #4
08-24-2008, 04:09 PM #5
i think thats about what i pay at wal-mart for the big bottle of P.P. ...i want to say 19.99 not on sale
08-24-2008, 04:14 PM #6Member
- tx
pewter- 99 trans am ws6
the big bottle of pp at walmart comes out to about 4 dollars a bottle
08-24-2008, 04:21 PM #7
hey sarge your fav oil question I switch from royal purple to P.P. I know you were saying that pp was beating almost all in the test just thought i'd check up money aside what would you put in your ride.
08-24-2008, 04:36 PM #8Grand Imperial Wizard
I have had excellent results with PP 10-30. I have Shaeffers Series 7000 10-30 in there right now. PP is excellent lube.....
08-24-2008, 07:16 PM #9I like turtles
- Aug 2007
- Corn and Soybean fields
I've heard PP has a high parafin content
08-24-2008, 08:32 PM #10
Is Checkers Auto parts the name of the store or would it be all auto parts stores?
08-24-2008, 09:27 PM #11
08-25-2008, 03:08 AM #12Grand Imperial Wizard
All oil has a paraffin base and PP/or even the yellow bottle conventional has no more or less than any other oil.
Furthermore folks confuse what exactly paraffin is in oil...they think it is the same as paraffin wax used in candles....nope...not even close.....This is leftover from the Pennzoil causes sludge myth from the 60's and 70's....I've read a mile of post on many forums and had many a face to face with folks who swear Pennzoil causes sludge....almost without exception it will end up with "well I know a mechanic who has rebuilt many engines and they were all sludged up and the driver used Pennzoil"......I always ask...."well has that same mechanic torn down a perfectly fine running engine running Pennzoil?"
...and of course the answer is always I dunno or of course not....here is the point......Oil..of any brand....is incapable of "making sludge"....Sludge is the result of A) inoperative PCV B) Ridiculous Oil Change Intervals C) Coolant leaks
The Pennzoil causes sludge or is loaded with candle wax rumor/myth is just as seriously retarded as if you beat your meat you'll grow hair on your palms. Basics of crude oil 101 kids.... Base oils that are refined from crude oil are colorless and pretty much odorless and are sold to the public as mineral oil. The crude oil is a combination of a lot of different chemicals, ranging from light gasoline types of fuels to waxes and tars. When you heat the crude oil, the gasoline and diesel oil boil off pretty early. Unfortunately, the mineral oil, paraffin, wax and tar molecules are all hooked up with each other, and it's not so easy to separate them from each other. Also, the crude oil contains the aforementioned aromatics, which are quite bad in your oil: they are very reactive, and when oxidized they cause all kinds of problems. Refining oil means trying to remove the bad stuff, while leaving the good stuff. The more bad stuff we remove, the better the oil works. So paraffin is in the crude day one....In 1959, Chevron developed a new method of refining base oils called Hydrocracking, where you process the raw oil at high temperatures and pressures with hydrogen and various catalysts. In Hydrocracking, many of the paraffin and wax molecules are broken up into mineral oil molecules, which increases the performance of the base oil dramatically. Also, far more of the aromatics and sulpher and nitrogen compounds are removed from the oil.
Since 1990, Chevron's process has been improved. In 1993, Chevron invented the Hydro-Isomerization process, where wax and paraffin molecules are reshaped into useful lubricants instead of simply being broken up into smaller molecules. By increasing the severity of the hydrocracking process, increasing the temperature and pressure and processing time to process more and more of the unwanted wax and paraffin molecules, the oil's low and high temperature performance and resistance to oxidation can be improved to the point where the distinction between mineral oils and synthetics becomes blurred. Chevron now licenses this process, called Iso- DeWaxing. This process of oil refining is becoming more and more popular, and in 2004 accounts for almost half of all base oils. Iso- DeWaxing not only produces much higher-performance oil, but also allows you to start with lower quality crude oil, making us less dependent on the few countries that happen to produce the purest crude oils.So I hope you guys understand now...Paraffin/wax is native to crude oil. Hydrocracked base stocks have been around longer than most of you lil shits. All oils have "it" in the base stock and that is a good thing. And I hope you didn't fail to see the distinction between synthetics and conventionals is a blurred line now as the refining process has improved significantly.
I have to go shave my hands now...have a business meeting in a few hours. Seriously though....no oil causes sludge nor has candle wax in it guys......Last edited by Sarge; 08-25-2008 at 03:12 AM.
08-25-2008, 04:00 AM #13
08-25-2008, 04:55 AM #14
08-25-2008, 04:56 AM #15
08-25-2008, 05:09 AM #16
08-25-2008, 06:51 AM #17
Base Stocks
I hate to muddy the water but what Sarge is referring to is what are called Group III base stocks. Group IV base stocks are a different story.
This is why some synthetic motor oils cost $4 to $6 per quart while others cost $8 to $10. It has to do with how the base stock is derived. Some are crude oil based, others are chemically engineered from pure chemicals.
CompSyn
08-25-2008, 12:53 PM #18
Mobil One USED to be a group IV base stock correct? Not anymore though.. Correct?
What oil sold now is a true Group IV base stock?
I just put PP in the TA and right after I left buying it I noticed a small shop that does tranny work advertising they sold Amsoil. How much extra is an oil change with Amsoil and what exactly am I getting that is so much better? I really am curious. It is such a great oil, I wanna know why... Then I will be buying that in 2500 miles. Plain and simple, I want the best oil in the TA, But I dont wanna get bent over because of some advertising bullshit.
08-25-2008, 01:52 PM #19Slow'er'Ass
- Thornton, CO
I am going to stick with PP in my daily drivers, but the T/A is going to get Amsoil.
Now...I wish the Checker Auto here was actually running this sale. I would go stock up. I am sure I would clear their inventory.
But...I was in there today. $6.69 a quart.
08-25-2008, 03:41 PM #20
mobil 1 is basically an overpriced semi synthetic these days. You could get Motorcraft 5/20 or 5/30 semi synthetic for like 2.50 a qt versus whatever they are getting for mobil 1 now. Last I check it was in the 5-6 buck range. The motocraft shit is probably just as good as mobil 1 nowadays.
Pennzoil Platinum....which weight?
By Hurley711 in forum General HelpReplies: 14Last Post: 04-12-2009, 09:59 PM -
Pennzoil Platinum Full Synthetic!
By Tnhillbilly in forum General HelpReplies: 23Last Post: 05-19-2008, 08:46 PM -
6 quarts Pennzoil Platinum motor free after mail in rebate
By kraemer94 in forum General HelpReplies: 4Last Post: 11-06-2007, 08:58 PM -
Pennzoil Platinum $.99 a quart
By lonewolf37 in forum General HelpReplies: 8Last Post: 11-04-2007, 11:56 AM -
Free Pennzoil Platinum
By Sarge in forum Almost Anything GoesReplies: 50Last Post: 11-02-2007, 10:39 AM
And it's not a gap
i wish there was one in my area...
