Results 1 to 20 of 20
Thread: Speedo off
    Member Piranhaz's Avatar
    Aug 2008
    Minnesota
    1999 Trans Am M6
    Speedo off
    I searched some past posts, but didn't really get the answer I'm looking for. I bought my 99 Trans Am a few days ago and the speedo is off by 10-12 MPH (higher than I am really going). It has the correct size tires on it so I'm not sure why it's off. I do not know the previous history of the car but I'm assuming everything is stock as far as gears etc. What can I do to get the speedo to read the right MPH?? Do I need to take it to a dealer???
    Thanks
    Chris
    Indianapolis
    2000 WS6 6spd Hooker LT
    Sounds like somebody put different gears in it, like from a 2.73 to a 3.23 or something. You can have somebody fix this with a programmer like Diablo, or if you know someone with an HP Tuners software or LS1 edit, if you know what your current gears are.
    Most dealers would probably be clueless, but call them and ask if you want to.
    Member screaminbird's Avatar
    Aug 2008
    Aurora, Illinois
    White/Gold
    99 T/A sold/67 Firebird
    i was just goingt o say the exact same thing
    Aug 2008
    Minnesota
    1999 Trans Am M6
    The car is supposed to have 3.42 gears as far as my code tells me. I'll have to verify that and go from there.
    Thanks guys
    Chirs
    Indianapolis
    6-speed, eh? Nice. Sounds like somebody put in 3.73 or 4.10. If the gears are not making much noise, I would definitely keep them!
    Aug 2008
    Minnesota
    1999 Trans Am M6
    Yeah! I was looking for awhile and really wanted a manual. I'll check it out tomorrow and see what gears they are. I'm curious now too.
    Chris
    That guy thearborbarber's Avatar
    SoDak
    White over Red
    1991 Suburban
    Jack up rear and count the number of time the driver shaft turns while you rotate a rear tire one time. Then you know your rear end ration.
    Aug 2008
    Minnesota
    1999 Trans Am M6
    Quote Originally Posted by thearborbarber View Post
    Yeah, that's the way I usually do it. It gets you close enough to figure it out anyway!
    Thanks
    Chris
    Indianapolis
    Easy to do with a normal clutch type limited slip, but my torsen works differently, loose until it feels the torque, always pulls both tires straight, right or left.
    And yeah, 6-speed FTMFW! That is why I sold my '98 TA, it had an AT with 2.73.
    Aug 2008
    Minnesota
    1999 Trans Am M6
    OK, I'm confused. I'm getting about 2.25 revolutions of the driveshaft per 1 rev. of the tire. This would = about a 2:23 gear ratio?? Can that be possible?? That's not even an option as far as I know. Am I doing something wrong here???
    Jacked up the car and tried turning the driveshaft but the wheel I was counting would slip and the other would turn. So I lowered one side to lock it and then turned the driveshaft to get the free wheel to turn and came up with this ratio. Is that really coming out right though???
    Maybe I'll just have to pull the cover and check it out.
    Any thoughts???
    Indianapolis
    You could use a helper, she could keep the other wheel turning the same as the one you are turning so they both have the same rotation and count the ratio that way. Or, like you say pull the cover and do the count, this way you can know when the last time you had new synthetic fluid put in.
    Aug 2008
    Minnesota
    1999 Trans Am M6
    Good point, probably just better off pulling the cover and putting new fluid in anyway. I don't know the history of the car.
    Formula Driver! 96Firebirdformula's Avatar
    Seymour, Indiana
    Batman Black
    1996 Formula
    Here easy was to figure out what gears you got. Just click 98 M6. Then look at RPM in the gear.
    http://www.f-body.org/gears/
    Aug 2008
    Minnesota
    1999 Trans Am M6
    They are 4.10's!!!!
    Chris
    Indianapolis
    Nice gears for a 6-speed. Did you get your speedo calibrated yet?
    Aug 2008
    Minnesota
    1999 Trans Am M6
    Yeah, everything is good to go. Got the Skip shift removed too, boy is that nice!!!
    Indianapolis
    I put in a SLP skip shift eliminator, I like it because when I see the skip shift light come on, I can either go into fourth gear or give the light the finger. Usually I give the light the finger!
    May 2008
    Verdigris, OK
    99 z28
    Quote Originally Posted by 96Firebirdformula View Post
    why no 99 a4 f-body?
    Member bballking_2007's Avatar
    Mo
    2000 Trans am ls1
    CUZ the a4 has four gears and the m6 has six gears! lol it would be WAY off.
    May 2008
    Verdigris, OK
    99 z28
    duh.
  1. speedo only goes to 25
    By mach2mack in forum General Help
    Last Post: 08-14-2011, 09:29 AM
  2. Speedo help
    By CARHAULIN in forum General Help
    Last Post: 09-05-2008, 12:25 PM
  3. Where can I get a new speedo?
    By Rojerlockless in forum Firebird / WS6
    Last Post: 08-10-2008, 06:45 PM
  4. GTO Speedo run. 53-114
    By juiced99ws6 in forum Almost Anything Goes
    Last Post: 06-07-2008, 02:31 PM
  5. speedo
    By lopezog in forum LT1
    Last Post: 09-22-2007, 08:57 AM
