    Aug 2008
    Minnesota
    1995 Pontiac Firebird
    bypassing the computer
    I met a guy a few days ago willing to sell me his ls1 from his 04 gto which was in an accident, the car runs fine, its just deformed now, but he told me that the computer was already sold... anyways, i was wondering if there is anyway to bypass the computer or anyway to set up the ls1 so it wont need the computer?
    p.s. i plan on putting the ls1 into a 1975 Trans Am
    Junior Member Khaotic's Avatar
    warrenton, va
    2000 SS Camaro
    Nope
    Quote Originally Posted by t0astm0nkey View Post
    You need the computer for the cam sensor crank sensor and firing of the injectors no way to get around it.
    Feb 2006
    2002 WS6
    The other option is to carb it and look for a stand alone swap kit. I believe there are a few companies offering them up.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Do you have all the harnesses, or just the engine itself with no wiring??
    If you are missing both the computer and the harness, I'd reccommend ordering the complete computer/harness kit from GM. Its a plug and play system, designed specifically for the type of application you have, which is an LS motor in an older vehicle. All you have to do is hook each harness wire to the appropriate sensor (they are marked and color coded) and then find a place to mount the computer, and you have a running, functioning engine.
    I believe its between $700 and $800 for the entire kit, which isn't bad considering what you're getting for the money.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    You can get a loaded PCM (computer!) for under $150 (possibly even half that much) if that's all he took...
    Junior Member 2002WS6TransAmT56's Avatar
    Aug 2008
    Grant, Alabama
    2009 CHallenger RT Six Sp
    Go the carbed route, much cheaper and easier to work with. There are a couple companies that make the stand alone harnesses, all it does is control the ignition part. There is also a front distributor drive kit that allows you to run normal distributor types with MSD(or similar) electronic ignitions so wont even need the stand alone harness for that. I think GM performance parts sells that also. You will lose the knock sensors so be careful of your tuning not to get too advanced in timing.
  1. Bypassing the Monsoon Amp
    By SMWS6TA in forum Stereo and Electronics
    Last Post: 09-07-2011, 06:22 PM
  2. Need Help Bypassing cats on a 2000 Camaro
    By JJHP381 in forum General Help
    Last Post: 04-08-2009, 05:03 PM
  3. Bypassing VATS
    By Txyoungguns in forum Computer & Tuning
    Last Post: 05-27-2008, 04:04 PM
  4. Question: Bypassing the AC with Serpentine belt
    By AtLarge in forum GM Trucks
    Last Post: 03-15-2008, 04:03 AM
  5. Bypassing monsoon AMP???
    By 02bluez28 in forum Stereo and Electronics
    Last Post: 05-05-2007, 10:39 AM
