Results 1 to 10 of 10
    irwindale
    orange and Red
    1990 CAMARO RS 2000 SS
    My Camaro SS is stalling when I use the AC
    My 2000 Camaro SS stales when I have the AC on and I come to a stop its a manual trany,I used my scanner no codes are showing up I just cant put my finger on it.I don't know if its the idle control value is the culprit I am at a loss.One person tells me its the fuel regulator and another telling me it could be the knock sensor. Has any one else has had this type of problem ?????
    Bragg NC
    Met. Sunset Orange
    01 SS
    You can pull your Iac motor off and clean it to see if that cures your problem.
    Use brake cleaner to clean it.
    J
    irwindale
    orange and Red
    Thank you
    I will do that first thing when I get home from work today and let you know if it works. Thank you
    Member fast enough Z28's Avatar
    Rowlett,Tx.
    98 camaro z28 m6
    I would use b12 if it doesn't fix it buy a new iat sensor. I had the same problem.
    TEXAS... U mad?
    Black / Stryker Blue
    2K WS.6/ 2K9 G8GT
    let us know the results!!
    irwindale
    orange and Red
    I will thank you guys
    I just want to say thank you for the help this is been a pain with this problem ??
    check out my rear caliper set up on my drift camaro hope you like it
    irwindale
    orange and Red
    Good morning I did the two suggestions
    I change out the ats had a extra laying around and took out the idle control valve and cleaned it off with some fine sandpaper and break cleaner. On the drive to work it ran better at idle but it staled once when I turned the AC on again. Then it stooped doing it was running fine. Its vary Sporadic it will run fine sum time then stall when I come to a stop lets see.
    Rowlett,Tx.
    98 camaro z28 m6
    Quote Originally Posted by 1990LS1camaro View Post
    Possibly loose alternator or battery cables
    Member DaddySS's Avatar
    Bergen Co. NJ
    2000 Camaro SS Conv.
    Has it been tuned? There are idle speed settings for A/C on vs. off, generally 50 rpms higher with A/C on.
    irwindale
    orange and Red
    The car still is doing it and it has gotten worse
    I just bought the car a month ago some els did a lot of work on the car how well it was done is any ones guess. I can tell it has been programed I swapped out the computer with a stock one and it would not even idle. So I assume they played with the idle speed settings if it is rite or wrong ???? The car has a heavy cam some time it just does not like to idle rite. But my other car with the LS1 has a larger cam and it runs like a champ just wants to run never stalls .On the way home from work it started stalling with the AC off and every time I would come to a sudden stop when the car is in neutral.????? I hate when people do half ass work on a car.
  1. my car is stalling
    By jAgZ28 in forum LT1
    Last Post: 03-12-2011, 07:55 PM
  2. Car Stalling??????????
    By ptownboy420 in forum General Help
    Last Post: 07-17-2010, 09:06 AM
  3. Help: car stalling
    By 99yellowz28 in forum General Help
    Last Post: 04-25-2010, 02:04 PM
  4. Car stalling
    By paulc87 in forum General Help
    Last Post: 01-24-2008, 07:48 AM
  5. Z stalling out
    By 94redmaro in forum General Help
    Last Post: 05-30-2007, 03:58 PM
