Results 1 to 3 of 3
Thread: Valve Stem Seal ?
01-02-2006, 01:00 AM #1LT1KING
- Nov 2005
- Fontana, Ca.
Black/Black- 96 Vert Z28-RIP/94 TT Z28
Valve Stem Seal ?
I'm replacing the valve stem seals on my LT1 AFR heads and see that the OEM style seals I purchased are quite different from the ones on my AFR heads. Do I need to purchase some aftermarket seals from AFR or what? The ones on the heads fit tighter and have a metal clamp around them, as apposed to the stock ones that don't have the clamp and fit loose. Any suggestions?
01-02-2006, 06:30 AM #2
call AFR.
01-02-2006, 05:40 PM #3LT1KING
- Nov 2005
- Fontana, Ca.
Yeah I checked their catalog and they do use different ones so I'm gonna call them up and see if I can get some. Thanks.
New valve stem seals the same for exhaust and intake valve?
By JehalinTA in forum Internal EngineReplies: 1Last Post: 07-03-2011, 08:16 AM -
Help: Valve Seal question.
By Lunatikgixxer in forum Internal EngineReplies: 0Last Post: 11-04-2010, 03:24 PM -
what is the GREEN plastic washer over my valve stem?
By greatwhiteZ28 in forum Almost Anything GoesReplies: 8Last Post: 09-27-2007, 06:00 PM -
Valve stem seals you think?
By 94redmaro in forum LT1Replies: 3Last Post: 02-18-2007, 08:55 AM -
Where to buy AFR valve stem seals?
By GOODZ/BADZ in forum Western MembersReplies: 4Last Post: 06-28-2006, 09:56 PM
