Thread: 94 T.A. Struts or shocks?
08-15-2008, 06:42 PM #1
Guys, I think I've got struts on my 94 T.A. I'm used to trucks so I'm trying to learn. Which struts do I need?
08-25-2008, 08:38 AM #2Member
- Oct 2005
- San Antonio, TX
Navy Blue Metallic- 2001 SLP SS Convertible
You have shocks, the 3rd gen had struts. What are you trying to do with the car?
08-26-2008, 01:38 PM #3
I'm needing to align the car and it squeeks when I go around curves and over bumps. I'm assuming the shocks are worn out. I thought that my year car had struts.
08-26-2008, 01:54 PM #4Member
- Oct 2005
- San Antonio, TX
Try to pinpoint where it is coming from, I mean the car is 14 years old and they're known to have squeeks and rattles even new. If you are going to stick with a stock ride height, I would suggest buying some Bilstein HD shocks for it, those should outlast the car. Before doing that, I would start replacing suspension bushings, do the easiest/cheapest ones first and see if it makes a difference. You can start by changing the sway bar mounts and end links to poly bushings, that is pretty cheap and easy to do, those tend to squeek when the rubber gets old.
Question: what shocks and struts to use??
By timothyodell2525 in forum Suspension and HandlingReplies: 16Last Post: 09-29-2011, 07:40 AM -
Do we have shocks or struts?
By Street Fighter in forum General HelpReplies: 23Last Post: 08-14-2011, 07:26 PM -
Shocks or struts?
By jeffsredt/a in forum Firebird / WS6Replies: 8Last Post: 07-21-2009, 04:40 PM -
What shocks/struts?
By JwMonE99 in forum Suspension and HandlingReplies: 2Last Post: 06-25-2009, 07:59 PM -
Shocks\struts Best Buy??
By natess in forum Suspension and HandlingReplies: 2Last Post: 12-17-2005, 02:48 PM
