Results 1 to 3 of 3
01-01-2006, 11:41 AM #1Junior Member
- Dec 2005
- iTrader
- 0
SLP Line Lock #25000 98-02 Camaro/Firebird
Brand new Line lock #25000.. Here is what SLP says about it:
An SLP exclusive, this unit is designed to fit all 1998-2002 V8- and V6-powered GM F-Bodies. Here's how it works: Press the brake pedal and flip the brake-control solenoid switch. Remove your foot from the pedal, and the solenoid maintains line pressure to the front brakes until the switch is released. This makes it easy to heat the rear tires while minimizing wear and tear on your car's rear brake components. You can also use the system to prevent a manual-trans car from rolling out of the staging beams at the starting line.
This kit is custom-fitted to the F-Body chassis and is fully compatible with the factory anti-lock braking and traction-control systems. It includes a waterproof electrical solenoid, an activation switch, plug-in wires, CNC-bent steel lines with correct OE fittings, mounting hardware, and detailed installation instructions.
131.00 shipped!!! Let me know
01-16-2006, 07:57 PM #2Junior Member
- Dec 2005
- iTrader
- 0
anyone?
01-17-2006, 08:20 AM #3your parts guy!!!
- cleveland ohio
- iTrader
- 48 (100%)
trans am 00 ws6- 1998 camaro ss vert
i little to much. ask like 100 shipped it will sell then thanks jeremy
2017 Chevy Camaro ZL1 has line lock for sweet burnout mode
By Ed Blown Vert in forum General Help - 6th GenReplies: 0Last Post: 06-26-2016, 10:40 PM -
Line Lock Look
By pajeff02 in forum General HelpReplies: 37Last Post: 11-04-2010, 09:16 AM -
Line lock/ brake line ?
By 2001z in forum Suspension and HandlingReplies: 3Last Post: 04-01-2007, 05:42 AM
