Results 1 to 2 of 2
Thread: What flywheel is this?
08-11-2008, 07:13 PM #1
so i was replacing my oil pan gasket [again] when i noticed this on my flywheel:
it's a bit blurry, but it says 1255 4130 H.
seems like a stock flywheel shouldn't be made of 4130, no? anybody got any idea what flywheel this is? when i installed this motor and tranny from the wrecker, i didn't notice any special clutch. that is to say, it was dirty and had a standard-sized, full-faced disk, and a pressure plate with the normal array of smallish fingers.
i only noticed this after i had spent a very long time cleaning up the bottom of the block, so i didn't want to turn the crank and risk releasing more oil. i figured this was probably sufficient, but when i googled the numbers, i came up empty-handed.
in any case i have no use for a steel flywheel, so if anybody wants to trade . . .~Jason
2005 Acura RSX: Daily Driver duties
1994 Toyota Corolla: the beater that just won't die!
"Fast, Cheap, Reliable. You can only have two."
08-21-2008, 06:36 AM #2
so nobody has a clue? maybe SLP or something?
Help: LS1 flywheel
By camarorus in forum General HelpReplies: 3Last Post: 01-30-2011, 03:43 PM -
Wanted: OK, what flywheel do you have?
By 01blackbird in forum Parts Wanted / TradeReplies: 0Last Post: 04-07-2010, 07:35 PM -
Flywheel...
By LT4Hawk9 in forum Manual TransmissionReplies: 1Last Post: 03-07-2009, 03:16 PM -
flywheel?
By chevyboy82188 in forum General HelpReplies: 0Last Post: 02-18-2009, 06:47 PM -
LS2 flywheel
By SS#1531 in forum Parts For Sale / TradeReplies: 1Last Post: 09-16-2007, 07:51 AM
