Results 1 to 13 of 13
12-31-2005, 07:16 PM #1Junior Member
- Nov 2005
- madison wi.
red- 2001 camaro z28
Can't get wheels off dam wheel locks
I need a lock removing tool does any one have one I could buy it or rent it
12-31-2005, 08:48 PM #2SUPREME member-oderator
- Nov 2005
- Lost in Texas
Custom Slate Blue- 99 B4C
There are so many different ones it isn't funny. Go down to a GOOD tire place, they are your best bet. I ended up beating an old socket onto them to take them off and just replaced them on mine
01-01-2006, 03:45 AM #3Junior Member
- Jan 2006
- Canada
black- 2002 ss
Or try your local dealer,they usually have a set or two of wheel lock keys to remove wheels with...Ive tried those $10 removers from autoparts stores too, they work well but its handy to have a vice so you can get the nuts back out of them once theyre removed and twisted into the socket.
01-01-2006, 10:45 PM #4
Best bet, well easiest bet is to buy some cheep sockets from an auto parts store and pound them on and throw away with lock inside. Unless you have a vice like mentioned above then you can hammer it out. in that case if you local Sears has cool associates you can buy one use it and warranty it. Make sure you get 12 point will make it easier and can use it more times. Sometimes you can only get 1-2 off with a socket because it starts to get out of shape. Good luck
-00BlueTA
01-01-2006, 10:54 PM #5Adios and vaya con dios
- Nov 2005
- Gadsden, AL
Victory Red- 2002 Corvette Z06
Originally Posted by 00BlueTA
Gotta love Sears
01-02-2006, 05:04 PM #6quicky06Guest
Other Option Is If You Have A Dremel You Have 2 Options
A. Slice A Grouve In The Top About 1/4" Deep And Try And Use A Flat Head To Get It Out(they Make Flat Heads That Atach To Ratchet)
B. You Can Use A Dremel With A Cut Off Wheel (same For Above) And Slice The Top Into 8 Sections Deep Enough So Yo Ucan See The Stud And Use A Big Screw Driver Or A Small Wedge And Split The Steel That Way.
Personally I Couldnt Use The Old Beat The Crap Outa A Socket Until It Fits Over Because My Locks Were Round With A Key That Goes Inside And In Order To Go Over The Lock The Socket Was Bigger Than The Whole.
And This Is Also Why I Now Have 4 Keys For My Locks. One By The Spare Duct Taped To The Fender, One In The Glove Compartment, One In My Room At Home And My Father Has The Other One(im 17)
01-04-2006, 06:37 PM #7Junior Member
- Jan 2006
- Canada
black- 2002 ss
wanted : new rims
seriously though, air hammers and dremels put you one step closer to f*king up your rims. whats that worth? its still cheaper to take a cab into town and buy a wheel nut remover if your tires are flat...its Im sure pepboys or somebody sells them, theyll even take off the hardened ones no problemo, then you can keep it in your glove box for when you see those rims you always wanted in the parking lot of the puff-daddy concert.
01-05-2006, 06:29 AM #8quicky06Guest
ive dremmeled and split dozens of locks with out a problem you jsut have to take your time. that and i put a pubberized coating on the well that way the sparks dont hurt the wheel.
01-05-2006, 10:25 PM #9
In any way shape or form its much easier to use a socket or other means than a dremel or air hammer. Time wise and risk. The ones that are round and you might have trouble with have other means also. some that look like a star kinda patter can use a 1/2 drive extention and will remove them the ones that are kinda flat you have to be more creative but deffinatly removable if you dont feel like finding the right socket and beatin the hell outta it. The only ones in my 7 year workin at shops that i used any kind of air tools on were VW Mercedes style that are bolt style nuts. But whatever floats your boat I guess.
-00BlueTA
01-08-2006, 12:53 PM #10
pound a socket on there....i lost my wheel lock and thats what i did...ive got a 2000...those wheel lock suck anyways.....but hey miraculously when i pulled my interior apart last week i found the wheel lock...after looking for it for 2 years...i found it...it got stuck up under a kick panel
01-09-2006, 11:15 AM #11
You can buy extra ones if you still have the card that was packaged with the lock-there is nothing worse than not being able to find it when you need it.If you are the guy trying to make a living in the shop there is nothing worse than the people that say "the what.." when you ask them where is the key.Please keep track of it or get an extra one or take them off and get regular lug nuts on there .
11-18-2006, 05:28 AM #12
11-19-2006, 10:04 AM #13Pistol Pete
- Nov 2006
- Cowboy Country Stillwater, OK
Bright Rally Red- 1996 Camaro SS
Am i one of the few that just went and bought the corresponding wheel key. that seems to be so much easier.
--------- Chris - 1996 Camaro Z28SS #1524 ---------
LT4 Cam Kit | Comp Lifters/PR's | Jet Hot LT's & ORY | Corsa RSC Exhaust | SLP Bilstiens | S-C/D Rotors | 1LE Elbow | !EGR/AIR
madZ tune | 17x11 Chrome ZR-1's | Berger Panel | Fillins | BMR STB | Autometer A/F & Trans Temp | !Mouldings | Zaino
Help: Wheel Locks...Where do they hide the key?
By ebby69k in forum General HelpReplies: 5Last Post: 04-01-2010, 02:25 PM -
Wheel locks
By knightryda01 in forum Wheels and TiresReplies: 2Last Post: 11-08-2009, 03:50 PM -
Wheel Locks??
By mrz28m6 in forum General HelpReplies: 9Last Post: 05-17-2008, 04:45 PM -
Factory Amcor Wheel Locks
By aerojt in forum Wheels and TiresReplies: 5Last Post: 08-05-2007, 03:03 PM -
***Misc. Parts: MP3 CD Player, Wheel Locks w/ Key, SEE PICS!***
By aztectt in forum Parts For Sale / TradeReplies: 0Last Post: 03-14-2007, 07:18 PM
