    Member feet739's Avatar
    Centennial, CO
    pewter
    2002 Trans Am WS6
    Ignition Mystery!!
    I own a 2002 TransAm WS6 and I have the strangest problem with my ignition. When I turn the key sometimes the car won't start. All of the dash lights will come on but the car won't even try to turn over. Other times the car starts with no problems. It can't be the starter because the starter doesn't even turn when I have this issue. I took it to the dealership and they kept it all day driving it around and it didn't do it to them once. They tested the electrical system and found nothing. The extended warranty company won't pay for the fix unless the car is dead when it is brought in but if it is dead, I can't drive it in!?!?! WTF! Can anybody give me an idea what the problem is. Randomly changing out parts is not the way I want to go. Other than this my car runs great!
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    Ignition Relay...$12 "fuse" at the local Autozone.
    Centennial, CO
    pewter
    2002 Trans Am WS6
    Where is the ignition relay fuse?? Thanks.
    Stang Killer TransAmFanatic's Avatar
    Feb 2008
    Harvey, La
    1999 Trans Am
    it also might be the key, look at your key and see if its filed down, also check the chip on the key, if thats filed down to sometimes the chip wont make contact with the ignition switch and the car wont start. thats what mine did. i had my car towed to the dealership and they replaced the whole switch and gave me a new key for $400.
    Laurel, Maryland
    2000 Grand Prix GTP
    Quote Originally Posted by feet739 View Post
    It in the fuse box under the hood on the driver's side behind the headlights...lift up the cover and there is a diagram on the underside that shows you which ones are the ignition (IGN).
    Dcdrummer LS1buckey's Avatar
    Delaware, Ohio
    pewter
    1999 Pontiac Trans Am
    I bet it's the "V.A.T.S" I had the same problem I just bypassed the whole thing no more issues.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Ignition module.
    My Dad's truck had the same exact problem. Look into that, the part is not usually very expensive, just the labor if you have it installed.
    Centennial, CO
    pewter
    2002 Trans Am WS6
    Thank's Ls1 Camino!! I found the fuse first,then started the car, every thing turned over just fine. Then as an experiment I took the fuse out just to see if the car would act the exact same way as it does when it wouldn't start.Also to see if the dash would light up the same...it did,and of course the car didn't start. So looking at the old fuse,it looks like a cube with 4 metal prongs that insert into the fuse box,and I noticed two of those prongs looked slightly scorched.So i put the new one in and it started perfectly,i will have to see if this was the problem after i drive it around for awhile,i feel that it is by the looks of the original fuse.I will let you all know By the way what is V.A.T.S.?
  1. Mystery MAF?
    By pajeff02 in forum General Help
    Last Post: 08-26-2015, 04:29 PM
  2. G&A Mystery Gun: Identify and Win!
    Last Post: 07-12-2012, 03:30 PM
  3. Help: Mystery Part
    By duweller in forum Firebird / WS6
    Last Post: 06-14-2010, 06:07 AM
  4. Question: Marvel Mystery Oil in Gas/Oil in the LS1
    By camaroluvr447 in forum Internal Engine
    Last Post: 10-07-2009, 08:27 AM
  5. Mystery Movie??
    By bmyers in forum Almost Anything Goes
    Last Post: 08-21-2007, 06:51 PM
