Results 1 to 20 of 21
    USA
    Velocity Yellow
    2008 Corvette Z06
    DOT 5 clutch fluid
    Just had my clutch fluid flushed out and put in DOT 5. HOPEFULLY this will solve my damn clutch pedal problem.
    Anyone else run this fluid? I know a lot of you run the Valvoline synthetic DOT 3 and 4 fluid, but I opted for this. We shall see when I hit the strip on Saturday.
    2018 Tahoe - Silver - OEM
    USA
    Velocity Yellow
    2008 Corvette Z06
    Update
    The fluid helped out a bit but the pedal is still losing grab and is somewhat sticking to the floor. It is a lot better than it was before though. And it seems to rebound faster than it did before too. I guess now its, "hello new master cylinder!"
    C=('.'Q) wultdat's Avatar
    Cross Roads, TX
    Electron Blue
    2002 C5 Z06
    I'm in the same boat as you. I flushed out my fluid and it does work better but yea, the problem is still there.
    USA
    Velocity Yellow
    2008 Corvette Z06
    Quote Originally Posted by wultdat View Post
    Yeah, and I am going to the track tomorrow and have no time to change anything else out. So wish me luck! I will update later and let you know how it goes with the clutch.
    Are you running OEM fluid still? Or did you upgrade?
    Cross Roads, TX
    Electron Blue
    2002 C5 Z06
    I'm using the Valvoline Synthetic Dot 3 & 4 fluid. Oh, and good luck!
    USA
    Velocity Yellow
    2008 Corvette Z06
    Yeah I bought both the Valvoline 3/4 and the DOT5 fluid to see how they work. I ultimately decided to try the 5 due to the higher boiling point.
    And thanks!
    New Jersey
    It has a higher boiling point because it's a synthetic fluid. You're not supposed to mix it with conventional fluid. I think you're going to be in for a rather large parts bill very soon?
    USA
    Velocity Yellow
    2008 Corvette Z06
    Quote Originally Posted by Ten5TireRacer View Post
    DOT5? And I didn't mix it. The whole system was flushed out twice. I think I will be ok.
    SATX
    2000 Trans Am
    DOT 5 is not endorsed by SAE, i dont know much about hydrolic fluids but if you want a better clutch, go with the drill mod, or a better clutch package. DOT 5 is too thick and refine, besides its silicone based. So mixing it, no matter how well you cleaned your old fluid will still cause your system to fail due to all the precipitation that will eventually corrode your lines just like a clogged artery . Hell using DOT 4 is taking a risk, but I use DOT 4 in my PTO and holds up well.
    USA
    Velocity Yellow
    2008 Corvette Z06
    Quote Originally Posted by hurraquio View Post
    Thanks for the info. I will get it flushed out again monday and replace it with Valvoline 3/4 synthetic. Probably will have to replace my master cylinder too
    SATX
    2000 Trans Am
    well not really, you didnt leave that in for a long time did you? I'd go with a better clutch package, in fact im looking for a clutch! lol i will be replacing the slave cylinder though.
    USA
    Velocity Yellow
    2008 Corvette Z06
    No, it's only been in for about 5 days now. I want to replace my master because of my damn clutch pedal sticking to the floor. Any ideas (besides the drill mod)?
    If I have to replace my slave, I will be replacing my clutch as well with the LS7 one.
    USA
    Velocity Yellow
    2008 Corvette Z06
    I just spoke with my transmission tech here, and he said there are no parts inside the clutch that can corrode due to the siliocone fluid. But alas, I will be changing back to the Valv synthetic and upgrading to an adjustable master cylinder to hopefully take care of this problem. And I dont think my slave is leaking, atleast it didnt seem that way when we flushed it.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Why is using DOT4 taking a risk?? DOT3 and DOT4 are merely specs that the fluid meets, hence the synthetic Valvoline DOT3/4 meets both specs and is therefore compatible with both fluids.
    SATX
    2000 Trans Am
    No the fluid wont corrode the lines but the condensation caused by it will.
    SATX
    2000 Trans Am
    Quote Originally Posted by Wesman View Post
    DOT 4 Has a higher resistance value (temp and psi) than DOT 3. Say that by some reason Dot 4 fluid is aging well by the time DOT 4 would break down some clutch components would be long broken before the fluid. (i hope made sense lol) It would be easier to show than to explain.
    USA
    Velocity Yellow
    2008 Corvette Z06
    But arent they rubber lines? I really dont know, I just was under the impression that there were no metal lines.
    SATX
    2000 Trans Am
    I'm pretty shure there is braided metal inside the plastic/rubber.
    USA
    Velocity Yellow
    2008 Corvette Z06
    Gotcha... well I hope it's not a big deal, I will be flushing it out again and putting in the Valvoline. As well as an adjustable master cylinder.
    Member WARP211's Avatar
    Feb 2007
    FairField, CA
    RED 35TH ANIVERSARY PKG
    2002 CAMARO SS 35th LE
    it sounds like you need to flush out the slave. Air trap in the lines will not help you clutch pedal return.. If all that check out okay then I would take a look at the master.
  1. Clutch Fluid
    By Neil in forum General Help
    Last Post: 08-07-2009, 11:38 AM
  2. Best clutch fluid?!?
    By SteelmanLS1 in forum Manual Transmission
    Last Post: 07-28-2007, 05:29 AM
  3. Low clutch fluid
    By chuckstop00 in forum Manual Transmission
    Last Post: 05-04-2007, 02:17 PM
  4. Best clutch fluid
    By Mr. Luos in forum Drivetrain
    Last Post: 12-06-2006, 08:26 PM
  5. clutch fluid
    By GottaHaveLS1 in forum Manual Transmission
    Last Post: 10-24-2005, 04:37 PM
