Results 1 to 15 of 15
    Marylandistan
    2001 Trans Am (sold)
    Thumbs down UMI torque arm relocation tranny crossmember insta
    Well what should have only taken me like an hour and a half took all day cause this thing didn't fit. Tranny mount hole would not line up. I ended up removing it and enlarging the mounting bolt holes with a dremel, then reinstalling. Over and over again. I was using an Energy Suspension tranny mount and read on another board it wouldn't work cause the stock rubber tranny mount is offset, the es poly one is not. Wtf? The stock crossmember fit with the es mount so I figured this would too. Anywho I got this thing on but had to beat it up pretty good. It makes some noise but not as bad as the tunnel mounted torque arm I had a couple years ago so I guess it will stay. If anyone is wanting one of these I'd say try the BMR one.
    old timer blue02Z's Avatar
    2002 Z28
    trifles
    That guy thearborbarber's Avatar
    SoDak
    White over Red
    1991 Suburban
    That's strange. The one I put in fit perfect.
    Marylandistan
    Quote Originally Posted by thearborbarber View Post
    Did you use a stock tranny mount? Maybe they sent me one for the wrong tranny.
    Dan's gave me fits. But I got it on.
    It was more my fault for installing parts in the wrong order.
    Marylandistan
    You runnin a full legnth ta? For some reason I thought you had a shorter tunnel mounted one...
    Quote Originally Posted by INMY01TA View Post
    I have the tunnel braced one.
    Dan went with the relocation and long arm in his A4 car.
    Marylandistan
    Ohh, gotcha.
    Brookville, PA
    2001 Z28
    So let me see if I have this correct....
    You use an Energy Suspension tranny mount that even Energy Suspension does NOT show as fitting your car in their catalog, and that's UMI's fault? Did you try it with a stock tranny mount, you know--like it was designed to use?
    No company can do anything about folks who just don't pay attention to parts fitment. You even read in other places that what you are doing was going to be a problem.
    Sam Strano
    SCCA National Champion (x6)
    SCCA ProSolo Class Champion (x5)
    2009 SCCA ProSolo Overall Champion
    Owner--Strano Performance Parts
    814-849-3450
    Marylandistan
    Quote Originally Posted by Sam Strano View Post
    I read afterwards. Get the fuck outta here with your crap. Stock tranny crossmember fit with the es fine. I'll bet %80 of the people out there run one too.
    Marylandistan
    This pic of the BMR one looks like it using an ES poly mount to me. I think UMI dropped the ball here. Could have used more room for adjustment on the tranny mount. (there's plenty of room for adjustment in the other direction ) Btw, I didn't have a stock tranny mount, hadn't had one for years and didn't know I'd need one.
    SoDak
    White over Red
    1991 Suburban
    Nope I used the ES mount. I ground the nubs on the bottom off to make it the same height as the factory unit. I eft everything loose until all the bolts were started and then tightened everything down.
    Marylandistan
    I did that too. Mine wasn't even close.
    SoDak
    White over Red
    1991 Suburban
    I wonder if there is a differnece between the auto and manual mount and you were sent the wrong one. I have used UMI stuff in the past and its been top shelf stuff. Then again you could have gotten a crappy piece.
    Marylandistan
    There is a different part # for T56, 4L60E, TH350 etc. Beats me. You can read my post on Tech where another guy said the ES mount wouldn't fit for him. http://www.ls1tech.com/forums/showth...=955312&page=3 Post #50, scroll down.
  1. For Sale: BMR Torque Arm Relocation Crossmember for T56
    By Orrin's Z in forum Parts For Sale / Trade
    Last Post: 02-27-2013, 08:49 PM
  2. For Sale: UMI torque arm relocation trany crossmember
    By JayTA98 in forum Parts For Sale / Trade
    Last Post: 07-08-2010, 06:26 PM
  3. umi adjustable torque arm and tranny relocation braccket for m6
    By ninobrn99 in forum Parts For Sale / Trade
    Last Post: 11-15-2006, 10:34 AM
  4. Replies: 1
    Last Post: 11-04-2006, 01:08 AM
  5. Replies: 0
    Last Post: 05-13-2006, 09:55 AM
