Results 1 to 16 of 16
    Feb 2008
    Washington
    2002 Camaro
    cant get this thing right
    jus put prc 5.3l heads and a ms3 cam and i had texas speed do the tune and tune it a second time and it still wont idle right. when i rev it up and let off it wants to die. it used to throw p0106 but thats gone from the tune and it is running extremly rich. i replaced the map and the IAC. taking all suggestions.
    i need help only have like three days of good driving weather left!!!!!
    N/A nitrously aspirated stangslayer98's Avatar
    miami,fl
    1998 trans am
    first i would get it dyno tuned, mail order tunes are not the best fix as far as tuning goes, you may want to check and see if you have a vacuum leak, if it still occurs i did this to my car not everyone will vouch for it, all i did was bend the a small tab on the throttle body kind of hard to explain anyway it worked for me good luck
    TN
    2005 GTO M6 Black
    2000 Z28 A4 Red
    What throttlebody stock? If so for that cam you might want to drill the bleed hole (one in the center of tb blade) out just a tad. I was able to get mine to idle without a tune with that cam by drilling that out to 1/4". Then as he said above get a dyno tune so they can tune idle characteristics better. Mine would crank with me out of the car cold with no problems. I did get a 114 LSA though so that might help a tad in my case though.
    Feb 2008
    Washington
    2002 Camaro
    it will start and idle fine its when i rev it up and let off is when i have the problem it will drop down to 400-500 and then go back up after a few seconds and its really rich.
    miami,fl
    1998 trans am
    how do you know its rich, you smell fuel out the exhaust? that is typical of a cam though you should get it dyno tuned
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    EPP is in Indiana and can get the car tuned the way that it should be for ya. Tell them that I sent you
    Feb 2008
    Washington
    2002 Camaro
    i have actually moved i live in washington anyone you would recommend out here
    2 SS's are better than 1 Jays00ss's Avatar
    Lathrop, Missouri
    NBM / Silver
    00 SS / 71 SS Elcamino
    Tuning takes much more time than an hour or two on the dyno. I worked with my tuner for a few weeks before we really got the tune down right. It really helps to do a dyno and a street tune where you and your tuner drive around in everyday situations. A lot of factors play into a correct tune. Weather, temperature, city driving, highway driving, how long you let your engine cool before restart. Patience is always the key word when you change so many different perimeters of your engine.
    Feb 2008
    Washington
    2002 Camaro
    so do you think with a little driving it should figure itself out
    Lathrop, Missouri
    NBM / Silver
    Quote Originally Posted by tcamaro98 View Post
    you will need someone that is tuneing your car ride a long with you and make the corrections as needed.
    Feb 2008
    Washington
    2002 Camaro
    oh ok thanks for the help
    Feb 2008
    Washington
    2002 Camaro
    anyone else have any suggestions
    It may.
    How many miles on the current tune?? Since the last tune?
    Since a climate change?
    Feb 2008
    Washington
    2002 Camaro
    the climate is the same the first tune had about 50 miles on it and the new one has 0 on it
    It normally takes a little time to learn the idle with a new tune.
    After falling to 400-500 does it pick back up to normal idle?
    It may need a little touch up on the tune...adding a little more idle air (if in fact it is fat).
    Feb 2008
    Washington
    2002 Camaro
    yeah it usally picks back up to normal this is the second tune that ive had from them they said they did adjust that a little bit
  1. OMG - What did this thing used to be?
    By Neil in forum Almost Anything Goes
    Last Post: 05-11-2011, 03:29 PM
  2. Anybody know what this thing is?
    By Knight in forum Almost Anything Goes
    Last Post: 04-08-2010, 03:36 PM
  3. Is there a such thing as.....
    By wanna_lS1 in forum External Engine
    Last Post: 03-03-2010, 11:03 PM
  4. best thing
    By victor111262 in forum Manual Transmission
    Last Post: 02-12-2009, 07:56 AM
  5. What is this thing?
    By samson_420 in forum Computer & Tuning
    Last Post: 11-10-2007, 08:14 PM
