Thread: Sigh
08-05-2008, 05:36 PM #1
Sigh
Since I have had the car for only a month I have been learning a lot about it.
I was getting a really hard shake so I took it to Autozone. Code = P0300. Multiple cylinder misfire. So I decided to dig into it.
I have replaced the Air Filter with a K&N. The original was really dirty.
So now I'm onto the plugs and wires. Seeing as how this is my first time I have decided to take my time and read about it as much as I can.
I picked up some ACDelco's today and started on the driver side. After I pulled the plugs I noticed that the porcelain was really burnt. I decided to check the gap on the plugs. Sure enough the 4 on the driver side was set between .030 and .041. This isn't right. From what I read it should be about .054 to .055.
My project for today was only the driver side. Tomorrow will be the passenger.
How would the spark plug wear if the gap was to close?
08-05-2008, 10:54 PM #2Impounded
- Oct 2007
- Beaver Dam KY
Im sure that gap would help the misfire. As for the passenger side have fun with plug #8. Other will chime in about it as well.
Well be here to help
08-06-2008, 02:47 AM #3
If plugs and wires doesn't fix it, you may have to look at one or more of your coil packs as suspect. Sometimes those will go out. Had one happen to me once. $20 per if I remember right.
08-06-2008, 05:53 PM #4
Hey,
Ok so I changed the plugs and wires on both sides.
Whats really shocking is the fact that the number 8 was kinda easy. I slid the socket onto the plug and then used my finger to figure out the angle of the socket compared to the angle of the ratchet. And poof she went right on. I didn't have to use an extension or a swivel.
There was two issues I ran into. Number one is that the number 6 cylinder was the hardest to get off and on. For some odd reason. And number two was getting the coil pack plugged into the number 8 wire. Now that was a bytch.
I went for a ride earlier and my idle is down to 800 or so and she is pulling a lot better. Only time will tell now if I get that code again.
O and all of the plugs were worn the same way. It was like the gap was way to much in. I noticed that I was getting shitty gas millage too. I wonder if that is a cause of the gap being to much in.
Well any way thanks for all your help. You guys rule!Last edited by flipsutter; 08-06-2008 at 05:56 PM.
08-06-2008, 09:01 PM #5Impounded
- Oct 2007
- Beaver Dam KY
badass
Now start moddin
*sigh* clutch issues
By laviente in forum Manual TransmissionReplies: 4Last Post: 08-23-2012, 02:04 PM -
Sigh... Panhard install... 3 hrs and counting ...
By 5abivt in forum General HelpReplies: 22Last Post: 08-01-2009, 08:52 AM -
Peeling off my tints and doing it again ... sigh
By 5abivt in forum Appearance SectionReplies: 6Last Post: 06-22-2009, 04:30 PM -
Sigh...
By DanWS6 in forum Rocky Mountain MembersReplies: 22Last Post: 12-17-2006, 11:58 AM
