Results 1 to 19 of 19
Thread: Weird problem
08-03-2008, 01:36 PM #1JOSEY FUCKING WALES!
- Nov 2005
- College Station TX
Black- 2000 &2002 Z28
Weird problem
Well....I went to do a burnout to say goodbye to some old tires.....but instead i said hello to new problems....
After burning the crap out of some old tires I stopped somewhere on the way back to check to see if i could do another.....well when i pulled into a parking space and came to a stop while it was still in drive it clunked and shut off.
I started it back up and threw it in drive and it instantly died
I repeated that 3 times.....
Thinkin I might have locked up my rear end I put it in reverse....
It hopped a couple inches and instantly died.....after that I tried going in drive again and gave it even more gas this time....it went....but soon as i came to a stop it would instantly die....
I was thinin its rear end problems but on the road on the way back it would surge even at a 45 mile an hour coast.....it wouldnt die but just surge.....if i came to a stop i had to hold the gas a little to keep it running....
I went to autozone and its not throwing any codes......
Anyone got a clue???
08-03-2008, 05:30 PM #2
sounds tranny/clutch related to me.
08-03-2008, 06:06 PM #3JOSEY FUCKING WALES!
- Nov 2005
Well......i just started driving the car around for a while to try and figure it out....
It finally popped up with a service engine soon light right after autozone closed lol....figures....
It feels more like tuning issues to me now....but that makes no sense cuz i have a great tune by RPM (ryans performance motors) from raleigh.....
I did however notice that it hadnt been as bad....
I checked the tranny fluid, and its low....not real low but in the warm range....
I dont know....I just changed the fuel filter.....got any other ideas?
08-03-2008, 07:23 PM #4Slow'er'Ass
- Thornton, CO
What exactly do you mean by 'clunk?'
08-03-2008, 07:29 PM #5JOSEY FUCKING WALES!
- Nov 2005
a clunk clunk clunk....almost like it was stuck in a gear or something was hitting something...a real deep clunk
08-03-2008, 07:32 PM #6Slow'er'Ass
- Thornton, CO
Did it hesitate before dieing?
Really sounds like a tranny issue....
08-03-2008, 07:32 PM #7slammed
- under the car cover
M.R.M. & C.E. Yellow- 01 TA & 02 CETA
Maybe youre torque converter clutch is locked in the engaged position. You say it cruises fine, but it wont idle. Normally a locked tcc would just cause a sluggish take off, but seeing as you have an aftermarket stall with a higher stall speed and taking off (normally mind you, not launching
) is not as easy as with the stock stall, is whats causing it to die.
08-03-2008, 07:35 PM #8slammed
Oh and believe it or not, low tranny fluid can cause all kinds of problems, so you might want to top that off and check again.
08-03-2008, 07:54 PM #9JOSEY FUCKING WALES!
- Nov 2005
God i hope its not a tranny issue....If it is i hope that low tranny fluid has somethign to do with it....mayb overheated a little.....the fluid did kinda smell burnt
Ive taken this tranny in out of this car more times than god!
08-03-2008, 08:08 PM #10slammed
When you drove it again, did it shift fine, when does the "clunking" occur, was it only that first time that it happened? Take a look at youre tranny fluid again, when you pull out the dipstick, put some of the fluid on youre finger and look for shinyness from metallic particals, and try to feel for them. You said it smelled burnt and it was low, hopefully its just that. Top off the fluid and see if you still have the problem, if not drain and refill with a new filter and check for debris while the pan is off, hopefully its not been run low that long and it can still be saved. Its cheaper than pulling it out and rebuilding it. Hope this helps, good luck and keep us updated.
08-03-2008, 08:15 PM #11I flame retards
- Aug 2006
- Baton Rouge, La.
QuickSilverMetallic- 2005 GTO M6
Man I love my M6!! Good luck on solving this problem man.
08-03-2008, 08:16 PM #12JOSEY FUCKING WALES!
- Nov 2005
I had just put the tranny in there 2 weeks ago....Ill try that
It hadnt really made the clunking sounds towards the end....it was just acting like a pretty poor tune
08-03-2008, 08:23 PM #13slammed
Then that first initial clunk may just have been things locking up, ex. tcc. Or it may very well be just a tuning issue, these computer controlled vehicles nowadays are very finiky. Either way, i hope its nothing too serious, good luck.
08-03-2008, 08:29 PM #14JOSEY FUCKING WALES!
- Nov 2005
thanx man...me too.....Im just gonna get the tranny fluid lvl back to normal... and see if it improves....if it dont im gonna look at cleaning the maf and everything
08-03-2008, 08:45 PM #15slammed
Saw the vid, at least it was a nice burnout!
08-03-2008, 08:49 PM #16JOSEY FUCKING WALES!
- Nov 2005
thanx man .... lol it was ok....my buddy cut it off halfway through.....I was too far away b4 i really started burning em lol
THey wouldnt stop smoking after i stopped though hahaha
I couldnt put em through it again cuz rubber started flying off in hte mid of that
08-03-2008, 11:12 PM #17
Dam that sucks! Hope its nothing serious and you get it all back to normal. Where's the vid of the burnout??
08-04-2008, 09:47 PM #18JOSEY FUCKING WALES!
- Nov 2005
http://www.ls1.com/forums/showthread.php?t=93604
well...i got what the codes were......one was a bad O2 sensor......lol figures huh?
the other one was a tranny management thing.......it said that on the handheld....but on their computer they couldnt find anything on it at all
I dont know....i got the code if anyone has a clue
08-04-2008, 10:26 PM #19
what was the actual code number?
Weird Problem?
By ADICECCA21 in forum Firebird / WS6Replies: 11Last Post: 05-07-2012, 04:36 AM -
Weird problem I've never had before...
By SajoR in forum Camaro / SSReplies: 5Last Post: 05-25-2009, 08:33 PM -
weird problem!
By barryz in forum General HelpReplies: 3Last Post: 05-24-2009, 11:14 AM -
Weird Problem
By 1993ta in forum LT1Replies: 4Last Post: 01-09-2006, 07:50 PM -
Need a little help here weird problem
By 98Roadster6speed in forum CorvetteReplies: 3Last Post: 09-29-2005, 03:35 PM
