Thread: Chassis Lube
    Chassis Lube
    I just changed my oil for the first time myself _ are there any lube fittings on the 2002 WS6? I could not find any.
    Thanks
    War Machine BIG GUNS's Avatar
    St. Louis MO.
    00 Trans Am/Auto
    I think most are high pressure nowadays. Similar to aircraft flush high pressure fittings. If they have any, you will need to scrape off some road shit and find a flush circular fitting. You will also need a high pressure lube fitting if they have any. Looks like a needle for a lube gun. When you go to pump it in, make sure you have it square or you will get about 20 psi of lube all over your face and eyes.
    20 years experience working on Military fighters with that type fitting. (if the T/A has them)
    Member vannatte's Avatar
    Noblesville, IN
    1998 Pontiac Trans Am A4
    I've been told none from the factory. Many aftermarket parts have Zerk fittings.
    Thank you _ I feel better having searched and found nothing....
    Senior Member clg82's Avatar
    Feb 2007
    California
    2000 Trans Am
    retired military? what branch? I was in for 4 years and now I work for a Weapons Test and Evaluation Squadron......
    St. Louis MO.
    00 Trans Am/Auto
    Weapons test and evaluation. That would be either the 422 at Nellis or the 46 AMXS at Eglin. I am an IMIS engineer. Sound familiar?
    St. Louis MO.
    00 Trans Am/Auto
    Or Edwards since your location is California.
    Feb 2007
    California
    2000 Trans Am
    The squadron is VX31 in ridgecrest california China Lake........
    St. Louis MO.
    00 Trans Am/Auto
    Okay, you're on F-18s then. AME/ SAME is the software for those. One of the guys up here in Navy AME testing used to work there. Fong something. Can't remember his last name.
    St. Louis MO.
    00 Trans Am/Auto
    I was in the Air Force and stationed all over really.
    Feb 2007
    California
    2000 Trans Am
    Cool man small world
    St. Louis MO.
    00 Trans Am/Auto
    Small world indeedy.
  1. Chassis Dyno Testing - How Bogus Is Your Local Chassis Dyno?
    Last Post: 07-21-2011, 09:52 AM
  2. Chassis Dyno Testing - How Bogus Is Your Local Chassis Dyno?
    Last Post: 01-22-2011, 01:12 PM
  3. Oil & lube
    By Blackout01 in forum General Help
    Last Post: 05-23-2007, 08:56 AM
  4. Lube Job??
    By thugtilidie18 in forum General Help
    Last Post: 05-22-2007, 10:20 AM
  5. Mr Lube Accident
    By KyleLs1 in forum Multimedia Section
    Last Post: 10-31-2006, 06:39 PM
