07-30-2008, 04:51 PM #1
02 b4c/melting marker light socket/bulbs***help
my 02 b4c is melting the marker light bulbs on the front and also torching the sockets. i have replaced the sockets and the bulbs twice. they are doing it again!! i was wondering, is it because the b4c has a high amp/high output alt.??? any ideas. thanks
07-30-2008, 06:27 PM #2
Are you sure you have the right bulbs in there? Sockets melt from excessive heat. Heat comes from either too much resistance ( bad connection) or a short in the wiring. The high output alternator won't do it by itself.
07-30-2008, 09:45 PM #3
Or wrong lamps. If I am not mistaken they should be 194s.
07-31-2008, 02:14 AM #4
the marker lamp has 2 bulbs. one is a 194 and the other is a 3157. it has daytime running lights. the lights are on all the time. park/marker/turn signal.
07-31-2008, 05:49 AM #5
I would lean towards short...
07-31-2008, 12:32 PM #6Bone it like you own it
- Sep 2005
- TEXAS... U mad?
Black / Stryker Blue- 2K WS.6/ 2K9 G8GT
short is common, but one other thing, these lamps are illuminated almost 100% of the time the car is on... generating extreme heat... then you go thru car wash, or water puddle, and the rapid cooling of the housing causes it to crack. next time you then introduce water/ moisture/ condensation, you cause a direct short thru the water...
Just food for thought. this is a common 97 up problem.
also, as a preventative measure, try slowing thru water puddles when possible, come to a creep. and if you know you are going to wash the car, disable the drl's about 30 min prior to the wash, giving the housings ample time to cool.
For those who don't know, turn the car off, raise the E-Brake "1 CLICK", then start the car.
07-31-2008, 09:35 PM #7
LED light bulbs
By chuckie669 in forum Firebird / WS6Replies: 61Last Post: 11-23-2009, 02:55 AM -
Light socket question
By knightryda01 in forum Firebird / WS6Replies: 3Last Post: 08-18-2009, 05:33 PM -
893 vs 860 Fog Light Bulbs
By turbojimmy in forum Firebird / WS6Replies: 4Last Post: 05-10-2009, 01:29 AM -
Question: SLP Fog Light Bulbs
By SOCAL WS6 in forum Firebird / WS6Replies: 1Last Post: 01-26-2009, 12:01 PM -
looking for 2 amber light bulbs. the DRL bulbs..
By djvaly in forum Parts Wanted / TradeReplies: 4Last Post: 11-30-2006, 10:21 PM
