Thread: Throw-out bearing maybe?
07-27-2008, 07:08 PM #1
So sometimes now when i have the clutch in, or am letting it out, theres like a growling kind've sound. It doesn't sound like it's grinding gears or anything..it's not as loud as that. but i'm thinking it may be the throw-out bearing. Anybody got any ideas?
07-28-2008, 03:45 PM #2
- Feb 2006
- Orange County, NY
I have that too sometimes. It is either the throwout or the pilot bushing.
08-04-2008, 07:04 PM #3
I don't mean to high-jack your thread but what is it when you get a bad vibration when you let of the gas or let it coast in neutral? I've got this problem and it only does it from say 50mph+. Any ideas?
08-05-2008, 06:34 AM #4
- Crystal Lake IL
Pewter- 2001 Camaro Z28 M6
depending the year, 4th gen f-bods have pilot bushings some have pilot bearings.
I know 01-02 had a pilot bearing, cars prior had a bushing. cant remember which years exactly.
a bad vibration, can be mean things, from a bad pinion angle to bad pilot bushing.
in regards to the growling noise, how many miles are on your clutch, could it be your friction/pressure plate, maybe. It could also be the throwout bearing too, 98-00 slave cylinders (which are topped with the throwout bearing) where revised numerous times into better slaves for the 01-02 models.
08-05-2008, 03:15 PM #5
It'll be a week or so but I'll finally get a chance to check the pinion angle to see if it's correct, then take a look at the ds, then go from there.
Bad throw out bearing
By MasonWS6 in forum DrivetrainReplies: 2Last Post: 10-19-2014, 06:45 PM -
Throw-out bearing or Pilot Bearing going out? Need help.
By werewolf in forum Manual TransmissionReplies: 3Last Post: 04-11-2013, 05:19 PM -
Throw out bearing about to pop!
By Z28er in forum Western MembersReplies: 0Last Post: 04-27-2010, 07:11 AM -
Throw out bearing question
By blk-ws6 in forum Manual TransmissionReplies: 6Last Post: 02-11-2010, 06:34 PM -
Does this sound like a bad throw out bearing?
By DarthD in forum Manual TransmissionReplies: 0Last Post: 04-17-2007, 11:20 PM
