    freshduckie
    Guest
    Quick catalytic convertor question
    2001 ws6 m6, my passenger side cat is clogged so I am going to replace both with Carsound high-flow cats, question----on stock application I just need 2.5" in/out and just cut off old one and clamp new one in?
    Thanks
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    I've been working in exhaust shops and what we would do there is weld it in-clamps are not considered strong enough in that application.This would involve removing the Y-pipe and cutting the convertors out -putting it back in place-then tacking things back together ,removing again and finish welding.I know this sounds like a lot of hassle but trying to do it any other way will involve more work or less than satisfactory results.Convertors generate alot of heat and welding is the only thing that will keep it together with the amount of vibration also.I would give it a shot if you have moderately good MIG welding skills.Otherwise I would pay someone to do it right.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    here's a free way to do it. the cats are covered for 8y/80k. take it to the dealer.
    freshduckie
    Guest
    Ok yeah weld in you say, I see your point here, so 2.5 in and out is fine right? I would have dealer do it but no codes thrown
    thanks
    nc
    2000 camaro ss
    how do you know its clogged?
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    How do you weld on the cats with stock manifolds? I just put on some random tech cats and they bolt-on like the factory cats do....welded the y-pipe to the catback though.
  1. Question: Catalytic converter question.
    By 5150 in forum Western Members
    Last Post: 07-22-2011, 05:19 AM
  2. DD Catalytic Converter Question
    By pajeff02 in forum General Help
    Last Post: 09-17-2010, 06:56 AM
  3. Question: Convertor Question
    By Bama99z in forum Automatic Transmission
    Last Post: 10-06-2009, 11:02 AM
  4. Catalytic Converter question
    By Ruthie in forum External Engine
    Last Post: 10-15-2007, 07:52 PM
  5. Headers and convertor question
    By Andy Lappin in forum External Engine
    Last Post: 05-14-2006, 04:10 PM
