Results 1 to 3 of 3
Thread: cam confusion
07-25-2008, 01:58 PM #1
- Apr 2008
- Broken Arrow
white- 95 f-150
cam confusion
i dont understand the cam numbers what do they mean
07-25-2008, 02:39 PM #2
you'll find more info if you go to a major cam manufacturer's website, i.e. Comp Cams or something.
basically there's:
advertised duration, measured in degrees: theoretically how long the valve is seeing a force exerted on it by the cam. not particularly relevant to anything, but you can still compare cams against each other based on this number. degrees are of crankshaft rotation.
maximum lift, measured in inches at the valve (or mm if you're looking at imports): the most the valve opens at any point
duration @ 0.05" lift: how long the valve is at open at least 0.05". much more indicative of actual duration. interestingly, the closer this number is to the advertised duration, the quicker the cam is ramping up to max lift, which is a good indication of how harsh the cam will be on the valvetrain components.
for any of these things, larger numbers generally mean more power in the top end, with sacrifice of low end. read up on a cam manufacturers' websites for more in-depth coverage.
there's also lobe separation, measured in crankshaft degrees as well. for this, the lower the number, the more lopey the sound, and it will drastically affect the difference between top end and low end/midrange power. a few degrees less separation can make a cam come alive at 5000rpm instead of 3000rpm.
check this out for some reading:
http://www.cranecams.com/?show=productNews
scroll to the bottom and start reading.~Jason
2005 Acura RSX: Daily Driver duties
1994 Toyota Corolla: the beater that just won't die!
"Fast, Cheap, Reliable. You can only have two."
07-27-2008, 08:26 PM #3
Lowering Confusion
By wicked1 in forum Suspension and HandlingReplies: 5Last Post: 11-16-2011, 01:05 PM -
Question: Muffler Confusion
By camaroluvr447 in forum External EngineReplies: 17Last Post: 03-12-2011, 12:35 AM -
Confusion: HID for T/A
By BashamWS6 in forum Appearance SectionReplies: 7Last Post: 11-22-2010, 08:42 AM -
98 4l60e confusion
By dfdexplorer1166 in forum Automatic TransmissionReplies: 6Last Post: 06-25-2006, 05:20 PM -
tire confusion
By baseballss in forum Wheels and TiresReplies: 12Last Post: 06-07-2006, 12:01 AM
