Results 1 to 20 of 30
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    victor jr intake for LS motors
    finally got mine today. started porting it.
    Orlando
    98 Camaro
    Are you just port matching or are you porting the runners? Just curious, I just bought the L92 single plane from GM and was wondering if I could take advantage of some portwork or not?
    Orlando
    98 Camaro
    Nevermind, after actually looking at the pics you posted, I answered my own question. Duhh!
    orlando, fl
    2014 camaro 2ss/rs
    i only went about 3-4" deep. i played a little inside the plenum to remove some casting flash at the port openings. i'm not going to get real crazy.
    orlando, fl
    2014 camaro 2ss/rs
    doylestown, Pa
    SILVER
    2004 CTS-V
    WOW! Nice! What do you have done to the engine so far?
    Orlando
    98 Camaro
    WOW, my 98 camaro is getting a carb with the same type manifold. Looks like I got some cutting to do. Your set up looks good, what cam are you using? Rear? Stall?
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    hmmm nice what made you switch rob? also curious on if you where running a fast or a ls6.. looks nice but i cant see that flowing better stock for stock with the elbow it has..looks like it was made for a carb
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by dvdslw View Post
    http://www.stealthram.com/2000pontiacformula.html
    wanted to do something different. i was running the NX intake. the intake was designed for carb applications. they made it for EFI as well.
    orlando, fl
    2014 camaro 2ss/rs
    i was originally going to go with a 4 barrel 1000 cfm TB, but i need my wipers. here's what you'll have to do to get the carb to fit with an air cleaner.
    orlando, fl
    2014 camaro 2ss/rs
    doylestown, Pa
    SILVER
    2004 CTS-V
    If you go fast enough, you will not need wipers!
    Shepherd, Michigan
    98' trans am
    i am 100% sure that with the nitrous set up rob is running..he is going fast enough
    Senior Member 01ws6er's Avatar
    The 717
    2001 Trash Can
    Looks nice! Did you have to do any hood or cowl cutting at all? 90mm TB? Friends cousin has pretty much the same setup on his 347 stroker 93 notchback...
    The 717
    2001 Trash Can
    ok I see the section of cowl you cut lol
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by 01ws6er View Post
    the cowl didn't need to be cut. i did that in prep for the 4 barrel TB i ended up not going with. later on, when i put the nitrous plate under the elbow, i might need the clearance.
    orlando, fl
    2014 camaro 2ss/rs
    Shepherd, Michigan
    98' trans am
    that pcv pipe is GHETTTO! rob-ghetto-tastic
    orlando, fl
    2014 camaro 2ss/rs
    i'll be painting it with krylon fusion black one day.
    Shepherd, Michigan
    98' trans am
    shit you gotta do what you got to do..let me know if your number improve ect....hows that trans holding up btw?
  1. victor headers
    By Resinblast in forum Camaro / SS
    Last Post: 04-28-2015, 02:06 AM
  2. Replies: 5
    Last Post: 01-30-2008, 10:20 AM
  3. Edelbrock Victor Stepped Headers
    By xssive in forum Parts For Sale / Trade
    Last Post: 04-25-2006, 08:33 AM
  4. Victor cutting torch
    By sg5492 in forum General Classifieds
    Last Post: 12-04-2005, 10:29 AM
