    Member totalkos's Avatar
    New Orleans
    Nbm
    T-top Adjustment?
    Is there any way to adjust the way a t top fits?
    I had to buy a new t-top and it just doesn't fit quite the same. it makes a lot of wind noise and just doesn't seal up as good.
    Simpsons Did it!! 98formy's Avatar
    Minnesota
    83 Z28 new project
    98 Formula WS7-sold:(
    If you take off the a pillar and/or the rear plastic piece where the back of ttop rod goes through, you will see a metal bracket thing with the hole in it where the ttop stud goes through. There are two bolts that hold it on. You can adjust it back and forth and there are also on some cars shims between where the bracket bolts up and the body. You can either remove those shims to lower it to seal it tighter or add some to do the opposite.
    New Orleans
    Nbm
    Quote Originally Posted by 98formy View Post
    Sounds like just what i was looking for.
    is this on the a pillar or b?
    Minnesota
    83 Z28 new project
    Both, you can adjust both sides where the ttop bracket is. Its the same part on both sides of the roof.
    tattoo artist,esquire sic2001's Avatar
    Huntington Beach, California
    navy blue metallic
    2001 trans am
    Take a dollar bill and run it through the cracks to fine tune the adjustments, I tweeked on mine till its perfect after I had my t-top fly off on the freeway.
    New Orleans
    Nbm
    awesome i figured it out and got it to fit right.
    Thanks so much guys. I was hoping that there was some sort of fix because there is no way that i could have stood all that wind noise and the shitty fitment!
    There should be a sticky about it!
  1. Headlight adjustment.
    By SS Camaro UK in forum Stereo and Electronics
    Last Post: 12-08-2011, 12:56 PM
  2. Question: Adjustment
    By william45 in forum Internal Engine
    Last Post: 04-28-2009, 06:10 PM
  3. kyb-abx adjustment
    By Danger731 in forum Suspension and Handling
    Last Post: 04-03-2008, 07:57 AM
  4. Help with PHB adjustment for 02 SS
    By riojames in forum Suspension and Handling
    Last Post: 01-29-2007, 06:29 PM
  5. speedometer adjustment
    By BITCHIN96Z in forum LT1
    Last Post: 09-10-2005, 12:21 AM
