Results 1 to 3 of 3
Thread: spring retainers & locks
07-19-2008, 06:41 PM #1
can i use the stock spring retainers and locks on beehive springs when doing a cam install?
07-20-2008, 03:57 AM #2
Springs
Depends on what type of springs your installing or removing, if their stock springs their already behive, and if your upgrading and their behive yes you can still use the locks and retainer.
But none behive springs use differant locks and retainers
07-20-2008, 05:39 AM #3Member
- Oct 2005
- RI
Mag Red- 2002 Vette
Retainers should have a "line fit", that is not too much slop and also not something you force into place. If you check the various manufacturers, you will find the ID of the spring is closely matched to the OD of mating retainer. Below is a quote from the PSI spring catalog.
TECH TIP
The interrelationship of the spring retainer, valve locks, and valve stem
(and their proper fit) is the most critical factor in determining the strength
and endurance of your valve train. The spring retainer and valve locks
should seat snugly to the valve stem and not rotate freely when pulled
together - in this position, the retainer should not rock from side to side.
Retainer fit with the spring is a critical relationship when determining
titanium retainer wear.
Double Valve Springs With Locks and Retainers
By ls1camino in forum Parts Wanted / TradeReplies: 0Last Post: 12-06-2008, 06:20 PM -
Stock ls1 seats, retainers, and locks
By quickz1670 in forum Parts Wanted / TradeReplies: 1Last Post: 01-08-2007, 07:21 PM -
Comp Cams New retainers and locks on Ebay
By Jason Polzer in forum Parts For Sale / TradeReplies: 0Last Post: 04-01-2006, 08:03 PM -
NIB 16 Super7 Titanium Valve Spring Retainers and 17 Pairs Of Locks
By negativeswitches in forum Parts For Sale / TradeReplies: 7Last Post: 02-15-2006, 09:08 PM -
LT1 valve springs, retainers, locks
By 642642 in forum Parts For Sale / TradeReplies: 0Last Post: 01-19-2006, 02:53 PM
