    Powerstrokin LT1 > LS1's Avatar
    Aurora IL
    Trans Am owner
    former
    buying a stored vehicle.
    well, I got 2 questions.
    1. my brake pedal isnt up to the spec I think it should be. I have to push it about 3/4 in just to hold in on a minor incline, and the braking performance is really lack luster. there is still a good amount of meat left on the pads, but I am thinkin that the brakes need to be bled.
    2. so, the guy before me had the car sitting in his garage for 7 years. and drove it a few hundred miles per year.....if that. I gave it an oil change, and I am wondrin if I should get on it a lot, and let it turn some good rpms. like cruise with the overdrive off, and such.
    will there be a build up of goo, or junk in the motor from being babied for so long? I heard somewhere thats what can happen, and it needs to be burned off. the cars bone stock, with 2.73's and chirps the 275 tires goin into 2nd gear, so it pulls pretty good, and doesnt feel down on power.
    Asshole bige97's Avatar
    Virginia
    '01 Silverado
    brake pedal bleed it and see what is does and or you brake pads could be worn.Can you hear it squeak? and for it sitting if he drove it around ever month or so it shouldn't be hurt any cuz the oil got moved around. Just change the oil and change the rear end oil if it hasn't been done.
    LTX N20LT4's Avatar
    Cali
    10's N/A
    Quote Originally Posted by nitrorustler41 View Post
    Motor should be fine as long as it's been driven from time to time. On a side note, it is interesting that they (GM) would equip the "Performance Package" with 2.73's...
    WI
    Blog Entries
    1
    09 EclipseGT 75 Chevy 4x4
    2001 Trans-Am 13 F-XT
    Flush the brake system. new fluid will do wonders.
    Member LT1 Hawk's Avatar
    Feb 2008
    Vista, CA
    Red and Black
    1995 Z28
    might be worth it to sea foam the engine...
    Aurora IL
    Trans Am owner
    former
    I sprayed degreaser all over the area of the front main seal ,becuse it looked a little grimy.
    I hope I dont have to replace front main seal. I wil lcheck back in a little while to see if there is more oil there
  1. stored 06 gto
    By BreathStealer in forum GTO
    Last Post: 04-19-2014, 05:59 PM
  2. Advice on buying a stored vehicle?
    By Tide in forum Almost Anything Goes
    Last Post: 03-20-2009, 06:10 PM
  3. buying a stored vehicle.
    By LT1 > LS1 in forum Firebird / WS6
    Last Post: 07-20-2008, 11:20 AM
  4. buying a new vehicle
    By dlmeadows in forum Almost Anything Goes
    Last Post: 12-14-2007, 06:58 PM
  5. car wants to stall after being stored
    By philsls1 in forum General Help
    Last Post: 03-16-2006, 04:05 PM
