Thread: 02 camaro window problem
07-17-2008, 06:35 AM #1
- Jul 2008
- Richmond VA
red- 2002 z/28 camaro
It seem that my z had a window motor replace a few years ago by a chevy dealer when they replaced, it seem that the rivets that hold the motor in place longated the holes, again it is in the shop they have to replace the motor lucky I have a extend warranty , but they do not cover the repair of the door damage ??? body shopy 250.00 or a new door 1,600 geee should I call the zone office (chevy) to see what they can do or just pay the 250, and they said this could be temporary fix renforcing the door with a piece of metal. what to do.....
07-17-2008, 09:10 AM #2
start here first window motor sticky and see if that helps you any.
I haven't had to do this swap yet so I can't give you much help. Check with Spaz on here as I know he did this swap and can probably offer much more help.
07-18-2008, 04:23 AM #3
I had the same proble, you can save your self the cash and do it your self... Took me about an hour to put sheet metal on the bracket, the cause is because the person that put your window motor in last was a tool and didn't know what he was doing with the rivits. they just pop them in and dont make sure that they are tight.
Do the sheet metal thing for now and fins a used door on the sites (got mine for 80 bux window, motor and all wires) then when you get the time / extra cash swap out the door and get repainted
07-18-2008, 05:34 AM #4
Do the swap yourself, pick up a motor from say chinazone with a lifetime warranty, instead of using rivets use a couple of bolts and lock nuts.
07-18-2008, 06:05 AM #5
- Nov 1999
- over here...
i'll agree with you...i riveted mine... and i'll say that when the rivet gun popped the rivet through i thought it was goingto shatter my window...
just watch for the door lock mechanism... i was sliding my window front and back and i hit that and broke the dang thing...
07-21-2008, 11:20 AM #6
- Jul 2008
- Richmond VA
Thank you for the information sent it seem the shop sent the car to the body shop and fix the door problem for now, now it seem that the alertnator is not working properly gee I wonder if they forgot to pull the fuse when working at it in the shop ????? life goes on, lucky for the extended warr.....
Another window problem
By Firebirdformula in forum Stereo and ElectronicsReplies: 4Last Post: 06-19-2010, 12:07 AM -
Window problem
By Sas in forum Firebird / WS6Replies: 6Last Post: 10-20-2008, 12:28 PM -
Camaro Electric Window Problem
By scooley in forum General HelpReplies: 1Last Post: 04-05-2008, 08:17 PM -
Camaro Window Switch/1le window/power lock delete kit
By Marc1130 in forum Parts For Sale / TradeReplies: 0Last Post: 03-12-2007, 11:05 PM -
window problem
By sgt0704 in forum General HelpReplies: 2Last Post: 04-30-2006, 01:59 PM
