Results 1 to 13 of 13
Thread: Pagemaker export to pdf problem
07-16-2008, 10:07 AM #1Junior Member
- Dec 2006
- USA
Blk/gld,Blu,Blk- 78TA,92RS,02Hawk
I am using Pagemaker 6.5 and am trying to export a document as a .pdf.
I am getting this error.
"Exporting a PDF requires a PostScript printer driver. Please install one."
What must I do in order to export my documents as pdf documents?
07-16-2008, 10:10 AM #2Detailing + Design
- Pittsburgh, PA
don't export it, go to file> print> select "Adobe PDF" or "PostScript file"
IF you dont' have adobe acrobat with Distiller installed-you CANNONT creat the ".ps" file
07-16-2008, 10:34 AM #3Junior Member
- Dec 2006
- USA
this may be a dumb question, but I am not wanting to print it. I need to save it as a file so it can be hosted on a site so people can download it and read it or print if they want. I have acrobat reader installed. I don't know what distiller is.
I also have photoshop and illustrator if that would help in any way.
It doesn't even have to be a pdf, just a file type that the people could open, view, print.Last edited by Bandit400; 07-16-2008 at 10:38 AM.
07-16-2008, 10:42 AM #4Detailing + Design
- Pittsburgh, PA
you want it as a PDF. I know it sounds weird, your' not printing a physical document, your printing it through the PostScriptor which will create a PDF on your desktop. Doesn't matter what other programs you have, if you don't have distiller i don't think you can create a ".ps" file.
07-16-2008, 10:42 AM #5Detailing + Design
- Pittsburgh, PA
might i suggest the following site for more "designer" help http://forum.howdesign.com/
07-16-2008, 11:06 AM #6Junior Member
- Dec 2006
- USA
thank you much
07-16-2008, 11:14 AM #7
I use a program called PrimoPDF. It prints the document, but not to a printer, it just saves it to a PDF file so whatever you would see on the paper is what you see on the file.
It's free and it's at primopdf.com
good stuff.
07-17-2008, 05:43 AM #8Junior Member
- Dec 2006
- USA
07-17-2008, 06:52 PM #9
watchout when using other program then adobe to created pdf's the can cause problems down the roads depending on what they are used for. PDF was created by adobe and are the only ones who uses their pdf engine.
07-17-2008, 07:24 PM #10
Primo works like a printer. It installs a virtual "printer" on your computer. It shows up in your printers and faxes window and you can even print certain pages of a document instead of a whole document just as you can print anything else.
When you set your print options, it opens up the primo program and asks you wherey ou Want the PDF saved and it creates the PDF in the chosen directory.
07-18-2008, 11:13 AM #11Junior Member
- Dec 2006
- USA
Wow, it works great! THank you so much.
So, if someone didn't use something like Primo to do this, what all would someone have to buy from Adobe in order to create pdfs? I have spent a lot of money on Adobe products already and none of them can do this.
07-18-2008, 11:16 AM #12
07-18-2008, 11:18 AM #13Senior Member
- Mar 2007
- Henryetta/Tulsa Oklahoma
Also works great in sending images that are in TIFF format...I print them to PDF, or convert them to JPEG to reduce the size. TIFF's are HUGE and I hate them...
Pagemaker 6.5 text box lines printing
By Bandit400 in forum Almost Anything GoesReplies: 3Last Post: 04-24-2008, 12:44 PM -
export taillights
By jz28 in forum Appearance SectionReplies: 16Last Post: 04-03-2008, 04:59 AM -
Export taillights
By uLs1a in forum Western MembersReplies: 19Last Post: 11-14-2007, 03:43 PM -
Z28 export version
By hamburger68 in forum Camaro / SSReplies: 5Last Post: 04-14-2007, 12:59 PM -
Export tail lights
By kev70ss in forum Parts For Sale / TradeReplies: 3Last Post: 03-29-2007, 08:43 PM
