Thread: bore and stroke
07-11-2008, 02:09 PM #1Junior Member
- Jun 2008
- lincoln ne
red- 1998 trans am
bore and stroke
how big can i go on a stock ls1 aluminum block? i wanna do a 428 cube, 4.125" bore 4.000" stroke, then turbocharge it
07-11-2008, 02:10 PM #2Slow'er'Ass
- Thornton, CO
You must have VERY deep pockets.
Without sleeving it, you shouldn't bore the stock aluminum LS1 block.
Sleeves get VERY expensive.
07-11-2008, 06:02 PM #3Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Can it be done? Sure....will it last? Nope.
LQ9 Iron Block and go have a blast....that is what it is built for.
07-12-2008, 08:11 AM #4
Or LQ4 block. Only thing with that is having a lower compression to start with if your using stock internals because of the dished pistons. Ether way, the iron block what your going to need for your application unless you go with the LSX block for 2000$
Stroke your stroker!
By hamburger68 in forum Almost Anything GoesReplies: 13Last Post: 02-15-2008, 02:03 AM -
need to know stroke and bore
By camaro 1999 in forum Internal EngineReplies: 5Last Post: 04-10-2007, 10:23 AM -
383 Stroke What do you think?
By Isma98Z28SC in forum Internal EngineReplies: 0Last Post: 05-24-2006, 11:25 AM -
stroke my ls1 or buy the slp 402?
By RyansREDcamaroSS in forum Internal EngineReplies: 23Last Post: 02-25-2006, 03:19 AM -
bore and stroke question? ws-6
By BANDIT28 in forum Internal EngineReplies: 3Last Post: 12-02-2005, 07:29 AM
