Results 1 to 20 of 40
Thread: roller Rockers on a stock LS1
07-11-2008, 06:12 AM #1Member
- Oct 2007
- CANFIELD, OHIO
PEWETER METALIC- 2002 CAMARO Z-28 M-6
Any gains from these or driveability issues on a stock motor with just a K&N FIPK and magaflow cat back? Im thinking the 1.7 ratio as I believe stock is 1.6 correct me if im wrong? Thanks for the help.
07-11-2008, 06:18 AM #2
07-11-2008, 06:29 AM #3
07-11-2008, 06:34 AM #4
07-11-2008, 07:15 AM #5
07-11-2008, 08:06 AM #6
If anything, upgrade to a better rocker that doesn't like to puke out needle bearings.
07-11-2008, 08:20 AM #7
07-11-2008, 08:36 AM #8Member
- Oct 2007
- CANFIELD, OHIO
cool I'll check those out. Thanks
07-13-2008, 11:00 AM #9Member
- Oct 2005
- RI
Mag Red- 2002 Vette
07-13-2008, 11:05 AM #10
07-13-2008, 11:15 AM #11Member
- Apr 2008
- allenhurst GA
black- 99 formula firebird
so with a bigger aftermarket cam what rockers would you recommend mr.luos
07-13-2008, 11:32 AM #12
07-13-2008, 11:44 AM #13
07-13-2008, 04:36 PM #14
A few thing to keep in mind w/ the rockers (and anyone feel free to correct me if you think I'm wrong)
1. The rollers will free up a few HP due to less friction/parasitic loss
2. However, the roller rockers are heavier, so more "mass" moving around.
W/ that being said, I would expect very little gain from rollers, but that's just MHO.
dale
07-14-2008, 02:16 PM #15Member
- Oct 2005
- RI
Mag Red- 2002 Vette
A longer pushrod will only alter the lifter preload, it will not alter the wipe pattern. Gm set up the rockers to run a certain lift and fixed the pivot location within a tolerance that would provide an acceptable wipe. As you alter the lift then the wipe changes, and not for the better. Most don't check wipe patterns when they set up a new cam.
One other point, as the wipe widens and you increase the spring loads to support and aftermarket cam, aftermarket heads with bronze guides will have a dramatic increase in guide wear. Bronze guides could wear out in as little as 10K miles given a bad setup.
07-14-2008, 03:00 PM #16Slow'er'Ass
- Thornton, CO
By wipe...you mean side to side movement on the valve tip correct?
I am running a .630 cam with stock rockers, and I have kept an eye on them. They haven't 'moved' side to side any more than it did when stock.
07-14-2008, 03:34 PM #17
07-14-2008, 03:47 PM #18
07-14-2008, 04:54 PM #19
07-14-2008, 05:11 PM #20
Roller rockers????
By blownh2x in forum Internal EngineReplies: 17Last Post: 10-20-2008, 05:10 AM -
roller rockers or stock??
By z28gc222 in forum Internal EngineReplies: 4Last Post: 09-12-2007, 06:07 AM -
93-02 LS1 LT1 HURST STOCK SHIFTER W/STICK Trade: TOWER BRACE/ ROLLER ROCKERS/ HEADERS
By chadnol10 in forum Parts For Sale / TradeReplies: 0Last Post: 01-18-2007, 04:35 AM -
Roller Lifters and Aluminum Roller Rockers
By MadSeason in forum Internal EngineReplies: 7Last Post: 03-14-2006, 02:23 PM -
anyone have the 1:8.5 roller rockers?......
By 5 ltr. beater in forum Internal EngineReplies: 9Last Post: 03-06-2006, 06:12 AM
