Results 1 to 2 of 2
07-10-2008, 10:09 PM #1Junior Member
- Jun 2008
- Texas, USA
Pewter- 2000 Camaro
A few LS1 swap questions?!?!?!?!?
1. I had a 3.8L 3800 II v6 in my camaro and it had electric throttle body and I am swapping an LS1 in and the throttle body is cable accuated. So would this work.....Buy a LSX throttle body that is electrically driven and add this to the wiring harness: http://www.exoticperformanceplus.com....html?item=743
2. If that isn't possible, how hard is it to add a throttle cable to the pedal through the firewall and all the other shit on the engine bay side of it then to the engine?
AND 3. What is the difference in radiator or coolant hoses between a 3.8L 3800 II v6 engine and an LS1?
Thanks in advance for the help!!!
07-11-2008, 02:42 PM #2Senior Member
- Feb 2006
- Orange County, NY
2. If that isn't possible, how hard is it to add a throttle cable to the pedal through the firewall and all the other shit on the engine bay side of it then to the engine?[/QUOTE]
AND 3. What is the difference in radiator or coolant hoses between a 3.8L 3800 II v6 engine and an LS1?[/QUOTE]
I would go with an LS1 radiator anyway, even if all the hoses line up. The LS1 will need a larger radiator anyway. You might even want to upgrade the cooling fans too, not sure if they are the same.
Thanks in advance for the help!!![/QUOTE]
There should be a hole already there, probably has a plug. If you can find a gas pedal and cable from a junker it would make it easier.
ls1 to ls2 swap questions
By slpws6ta in forum General HelpReplies: 1Last Post: 03-28-2010, 09:25 AM -
swap questions
By Al Hazz in forum DrivetrainReplies: 9Last Post: 05-17-2009, 05:25 PM -
LSX swap Questions
By casperss in forum General HelpReplies: 13Last Post: 12-26-2008, 02:33 PM -
Help: 98 T/A LS9 Swap Questions
By 317Born in forum General HelpReplies: 16Last Post: 12-21-2008, 09:42 PM -
V6 to V8 swap questions
By bigship in forum General HelpReplies: 14Last Post: 10-07-2008, 01:51 PM
