Results 1 to 11 of 11
Thread: A/C filter???
    san antonio
    green
    2000 trans am
    A/C filter???
    i own a '00 trans am, andi just recently replaced a/c lines, and oriface tube, i also vaccumed the entire system, and installed some freon.Know... is their any other kind of air filter maybe inside the dash somewhere?
    Junior Member b-man's Avatar
    Bright Silver Metallic
    2002 WS6 T/A Convertible
    Not unless you own a 2002, that's the only year F-body that had a cabin filter.
    san antonio
    green
    2000 trans am
    can i use the '02 setup and swap it for the one on my '00?
    Can't help ya on that one.
    Just today I was searching the 'net to see if my car even had one, turns out the '02 cars were the only ones factory equipped with one. Not sure if they can retrofitted to one of the earlier 4th-gen F-body cars.
    Feb 2006
    2002 WS6
    really? the 2002 F-bodies have a cabin filter? Are you sure? I haven't seen any way to access one let alone any type of housing for one
    Here's the filter:
    http://www.partsamerica.com/ProductD...tNumber=CF8804
    Different GM cars that it fits:
    http://www.partsamerica.com/ProductG...tnumber=CF8804
    I'm going to dig into my car and try to replace mine as soon as I can buy a cabin filter, my car has a little under 22K on it now and I'm sure it's past time for replacement.
    I would assume it's somewhere behind the glovebox. I just replaced the one on my '06 Civic and it took all of 2 minutes to do the job, simply dropped the glovebox/door unit down on its hinges by pressing in two tabs and slid the old one out and put the new filter right in.
    Somehow I think replacing the one on the the T/A won't be quite that easy, I haven't had the pleasure of laying down under the dash with a flashlight to take a look just yet.
    I do have a set of Factory Service manuals here, but unfortunately they're for the 2001 F-body cars (bought them used from a friend at work who had sold his '01 Z-28) and they don't show any cabin filter like I would expect an '02 manual set would.
    Tulsa,OK
    Quick Silver
    2002 Z06
    Like said above only the 02.
    The really screwed up thing is my 02 Z06 does not have a filter only the 04 model as far as I can tell.
    Let us know how the install of one goes if you decide to try and put one in.
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
    Senior Member
    Jacksonville, FL
    Why would GM just put them on the last model year, doesn't list Camaro either? I doubt they're correct.
    rapter34
    Guest
    Quote Originally Posted by 2001NBMZ28 View Post
    becasue GM fixed a lot of things over time with the F-body just like any other car. Also im sure these would work in a 98-01 but not sure if they would have a trap door to get them in.
    Senior Member
    Jacksonville, FL
    I won't believe it 'til I see one installed.
    MOTOR CITY MARO' SSTODD's Avatar
    LIVONIA,MICHIGAN
    PEWTER
    2000 CAMARO SS #3821
    FWIW the grand prix 97-03 is under the windshield base plastic cowl and never came with one from the factory, but the Buick did so you can buy it and put it right in because the tray is already there. The filter sat over the blower motor box. I had to remove the wipers and then the cowl to access the area.
  1. SLP lid or K&N Filter what is better
    By Durango in forum External Engine
    Last Post: 12-12-2008, 03:23 AM
  2. K n filter
    By pmolina0436 in forum GTO
    Last Post: 11-24-2008, 04:43 PM
  3. LT1 K&N filter
    By blackhawk01 in forum LT1
    Last Post: 04-15-2008, 11:28 AM
  4. k&n filter and slp maf fs
    By smax in forum Parts For Sale / Trade
    Last Post: 07-09-2006, 04:16 AM
  5. K&N Filter/Lid
    By 00\/\/S6 in forum General Help
    Last Post: 06-18-2006, 08:19 AM
