    Member 666ws6's Avatar
    Greenville, SC
    2000 Trans Am Ws6 #2946
    APE contact info for tune? Michigan
    I had my TA dyno tuned by APE in Clinton Twp Michigan years ago. Are they still in business? The # I have is disconnected.
    I'm trying to retune the PCM after changing gears, but the PCM is locked. Anyone know the code they might have used or how to get around that? I didn't know they'd lock it.
    What should I do? THX!
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    If it is locked, you need the key they locked it with. Not even a dealership can work with a locked PCM.
    Greenville, SC
    Angry
    Thanks guys, looks like APE has gone belly-up.
    Anyone know someone who worked there or still have a contact with anyone from APE?
    I'm hoping they used a standard key to lock a PCM... so maybe I can get it from someone. I'm just looking for the key/code to unlock the PCM, that's it.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Well fortunately, they are relatively inexpensive, but you will need to have the car retuned. With a little hunting around, I'm sure you can find a replacement for less than $100. Also, any year from 99-02 will work as a replacement.
  1. Contact info for us exotics?
    By ron d in forum Firebird / WS6
    Last Post: 08-25-2015, 02:54 AM
  2. Midwest Chassis contact info?
    By HOBS in forum Drivetrain
    Last Post: 08-15-2010, 04:33 PM
  3. Setting Up Ignition Contact Points - Contact Point Connection
    Last Post: 10-29-2007, 01:20 PM
  4. Program to capture contact info?
    By MagicMan in forum Almost Anything Goes
    Last Post: 07-13-2007, 09:19 PM
  5. If Anyone Wants Packy's Contact Info...
    By Sassy Cassie in forum Southern Members
    Last Post: 11-24-2005, 04:24 AM
