Thread: what tranny cooler should i get?
07-03-2008, 11:29 AM #1Member
- Jan 2008
- texas
White- 99Trans am
i just bought a tci 3500 stall are all tranny coolers universal and do you need a shift kit when you do cooler and stall? all help will be appriciated
07-03-2008, 11:45 AM #2Senior Member
- Jul 2005
- Jacksonville, FL
B&M 24K is a favorite, been in my car for years with no problems. I don't have a shift kit, just got a converter tune to increase the line pressure some, raised in gear idle, delete torque management... I'd say try a tune first, you can always change the pressure back to stock and then go through the expense of a kit and installation. I initially bought a shift kit, still sitting here unopened.
07-07-2008, 09:22 AM #3This Light Dinner Is Over
- Jan 2007
- Hamburg, Germany
Silver- 1998 Camaro Z28 A4
i got a 29 x 19 x 2 cm oil cooler, i think it's a b&m. no extra measures like a shift kit and works perfect.
oh, and i raised the shift firmness / pressure with a hypertech programmer, worked fine for me.
07-07-2008, 11:04 AM #4
I have the B&M 24K as well. I'm running a Yank 3600 converter and have no problems.
07-08-2008, 05:04 AM #5
i run a hayden 405 in my cars. near the bottom is how i installed it
http://stealthram.com/transmissionremove.htmCold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
07-08-2008, 06:46 PM #6
07-09-2008, 07:14 AM #7Member
- Jan 2008
- texas
White- 99Trans am
does the hayden kit comes with all you need or is there something else you have to get
07-09-2008, 08:05 PM #8
07-10-2008, 08:00 AM #9Member
- Jan 2008
- texas
White- 99Trans am
dam payed 45$ online
07-10-2008, 06:56 PM #10Senior Member
- Mar 2008
- OHIO"S only 9 second GTO
Phantom Black Metalic- 2005 GTO
they make some nice ones with a built in fan those are awesome they just turn themselves on when temps get above 175.
07-10-2008, 06:58 PM #11
07-11-2008, 01:22 AM #12
B4C comes with tranny cooler is that enough
By Z28boy2000 in forum Automatic TransmissionReplies: 7Last Post: 11-03-2009, 05:03 PM -
Question: Best tranny cooler to buy?
By clg82 in forum Automatic TransmissionReplies: 10Last Post: 04-05-2009, 03:38 PM -
tranny overheating, need bigger tranny cooler?
By djvaly in forum DrivetrainReplies: 22Last Post: 03-22-2007, 03:25 PM -
tranny cooler for m6?
By third_shift|studios in forum Manual TransmissionReplies: 12Last Post: 10-11-2006, 09:00 AM -
Tranny Cooler
By easyericvan in forum DrivetrainReplies: 8Last Post: 01-02-2006, 06:06 PM
