    Houston
    Camaro SS
    Exclamation Will Stock C6 Corvette Wheels & Tires fit properly
    Has anyone bolted up a set of stock C6 wheels with stock C6 size tires to their F-Body?
    Does anyone know if stock original equipment 2005-2008 Corvette C6 18 & 19 inch wheels and stock size C6 tires will fit properly on a 2002 Camaro SS convertible or a 2002 Camaro Z28 coupe?
    If not, what all must be done to get them to fit correctly?
    Are they the correct offset or will they stick out, or fit too far in and rub?
    Will the 245/40/18 and 295/30/19 stock C6 tires fit properly without rubbing?
    Thanks!
    One bad Z
    Jan 2008
    North Carolina
    1999 Z28
    They should fit
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    what are the stock offsets ?
    Eugenio_SS
    I need some money huggerls1's Avatar
    Feb 2007
    chandler az
    hugger orange
    1999 camaro ss
    Quote Originally Posted by Eugenio_SS View Post
    the c6 z06 wheels i like are 18x9.5 and 19x11 offsets are 57mm 64mm and thats front and rear im guessing, what would have to be done for these to work? my car is aslo lowered
    Jun 2002
    Montreal, CANADA
    triple-black
    for the rear, you'd need a 9/16" spacer... 1/2" might be too close.
    fronts are no issue.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
  1. C6 Corvette wheels and tires
    By 001CamaroSS in forum Parts For Sale / Trade
    Last Post: 03-14-2011, 08:23 AM
  2. 01WS6 stock wheels with tires & stock spring
    By SpinsB in forum Parts For Sale / Trade
    Last Post: 10-04-2010, 03:27 PM
  3. FS: Stock TA wheels with BFG tires
    By MagicMan in forum Parts For Sale / Trade
    Last Post: 09-24-2006, 06:11 AM
  4. Stock wheels & tires F/S
    By LS1-STANG in forum Parts For Sale / Trade
    Last Post: 01-17-2006, 07:53 PM
  5. stock 02 z28 wheels with tires
    By JD_Z28 in forum Western Members
    Last Post: 08-23-2005, 03:04 PM
