Results 1 to 20 of 36
Thread: Why am I running rich?
06-30-2008, 11:29 AM #1
Below is a list of my mods when i hook up a handheld for my "SES" light it says i am running rich.........WHY?
06-30-2008, 11:35 AM #2Slow'er'Ass
- Thornton, CO
@ handheld.
Get a wideband on it if you are that worried about it.
Anytime you allow air to come in and get out faster and at higher volumes, the stock tune will start to go rich.
06-30-2008, 05:34 PM #3
06-30-2008, 05:57 PM #4
would your MAF throw anything off.. alot of ppl say that it is worthless and dont need it.. its good for milage.. i looked at the mods... u might throw off ur air/fuel ratio... idk
06-30-2008, 05:58 PM #5
also have u ever had o2 sensor problems.. every bird does its a matter of time
06-30-2008, 07:24 PM #6
already had my o2 censors replaced
06-30-2008, 08:00 PM #7Slow'er'Ass
- Thornton, CO
More air coming out of the motor faster will register more air at the O2's...and the computer will make up for it with more fuel.
07-21-2008, 09:30 AM #8
07-21-2008, 09:53 AM #9Slow'er'Ass
- Thornton, CO
MAP sensor and MAF sensor will both read more air coming in...and assume it needs a bit more fuel.
This is why MOST of the bolt-ons cause our cars to go rich.
The factory is already a bit fat.
07-21-2008, 10:18 AM #10
07-21-2008, 10:21 AM #11Slow'er'Ass
- Thornton, CO
Rich won't hurt anything. Other than a little bit of power.
You need to get a wideband on it to see how bad it really is.
07-21-2008, 01:08 PM #12
07-21-2008, 01:28 PM #13
Sending your PCM in to get tuned???? Hmmmmmmm, there something about tuning a car without the car is what worries me.
2010 Camaro
2006 GTO, LS2, 1 of 475
2009 Chevy Silverado
07-21-2008, 01:30 PM #14
07-21-2008, 01:32 PM #15
07-21-2008, 01:34 PM #16
Just scan and tell us what the DTC is, as I mentioned last week.
07-21-2008, 01:57 PM #17
^^^will do i am going to go to kragen right after work and then i will post up the codes.
07-21-2008, 03:50 PM #18
I don't know what kragen is, but if you picked up the code with the handheld before, why not use it again?
07-21-2008, 05:30 PM #19
Ok here is officially the codes: P0155- o2 heater circuit, bank2 sensor 1 and the second code is P0401- exhaust gas recirculation flow insufficient detected what exactly do these mean?
07-21-2008, 05:45 PM #20Slow'er'Ass
- Thornton, CO
It appears the O2 is creating the rich condition.
What O2's did you replace? Which ones did you put in?
The passenger side O2 appears to be having a problem.
Question: running rich?
By BlairF in forum V6Replies: 7Last Post: 10-12-2010, 09:13 AM -
Running WAY Rich
By Krazy351w in forum General HelpReplies: 6Last Post: 06-05-2007, 10:28 AM -
Running rich... what to do?
By Red00WS6_DreamBird in forum General HelpReplies: 4Last Post: 11-05-2006, 06:50 PM -
im running rich
By PgaNick in forum General HelpReplies: 7Last Post: 08-02-2006, 09:16 PM -
running pig rich
By z28rktec in forum General HelpReplies: 8Last Post: 01-26-2006, 08:45 AM
I was just curious as to what affects the air fuel ratio......anyone else with an idea
