Results 1 to 16 of 16
12-26-2005, 06:40 AM #1Senior Member
- Jul 2005
- Earth
414 RWHP 395 RWTQ- 00 Black Ram Air Trans Am
What could rattle inside the car? Passenger side rear....
I thought it was the spare tire so I took it out and the rattle is still there
It picks up at around 25 mph and up, it's def. inside the car and is a real light rattle, but still 100% annoying. Any suggestions?
12-26-2005, 07:44 AM #2
I have the same thing...happened when I replaced the passenger side rear parking light, I was thinking it's the spare also since I had to remove it. I reseated the spare and it still rattles...maybe it's the jack
12-26-2005, 07:47 AM #3Senior Member
- Jul 2005
- Earth
Severe---nope my jack is out too, going for the 15 lb. weight reduction
It's not that either, it's driving me freaking nuts, it's the rattle that I hear but no one else really notices. At above 50 mph it's really annoying
12-26-2005, 11:43 AM #4Detailing + Design
- Pittsburgh, PA
do you have after market exhaust? could be bangin' around the wheel. mine does it at idle
12-26-2005, 12:56 PM #5Senior Member
- Jul 2005
- Earth
Yeah check sig
'00 Black Ram Air TA TR224/224 PRC 5.3 59cc Heads
Pacesetter LT ORY Hooker CB 414 RWHP 395 RWTQ
BMR PHR, SFC,LCA & TM. Bilstein HD shocks 1LE FSB
Firehawk Rims w/KDW Custom Headrests & Floormats
12-26-2005, 10:06 PM #6
rear pass exhaust hanger
12-26-2005, 10:15 PM #7The one I have is definatly from inside the car...passenger side trunk area. It didn't do it until I removed the spare...gonna take another look at it tomorrow.
Originally Posted by Orange SS
12-26-2005, 10:28 PM #8
maybe the panel, if you dont have the front 2 hooks engaged fully it could bounce a little
12-26-2005, 10:49 PM #9Member
- Sep 2005
- southern illinois
Bright Silver Metallic- 2000 Formula
check to see if your sensor for the stock alarm is just floating around back there, its not very big and plastic so it could be bouncing around in there maybe
12-27-2005, 04:31 AM #10
That could be it. I heard the same noise and it drove me crazy for about three months and just happened to be changing a flat one day and had that cover off and noticed the wire just dangling. Tied it off and no more noise.
12-27-2005, 04:31 AM #11Junior Rocketeer
- Sep 2005
- Russiaville, Indiana, United S
Sunset Orange- 2001 Z28
The Amp's back there too isn't it?? maybe worth a check.
Originally Posted by calb80
On my '94 I did have the rattle but it turned out to be the Lug wrench in my case. I ended up wedging a thick piece of cardboard in there and it stopped.
12-27-2005, 08:19 AM #12pbogdanoZ28Guest
Similiar problem
I have 2000 Z28, My driver side would make a noise as I went down the road, I had a buddy sit in the back and he pinpointed it to the upper shock area. I was under the car one day and as i lifted, by hand, the rear end under the shock mount I would hear a slight ping from the shock. didnt take much to make the noise. I replaced the shocks and that cleared it up.
it was a high pitched ping but not a loud ping. but it drove me absolutetly batsh*t.
hope you find it.
12-27-2005, 01:50 PM #13Senior Member
- Jul 2005
- Earth
Thanks guys, gonna check panel this weekend
12-27-2005, 03:14 PM #14Senior Member
- Jul 2005
- Earth
Ok just to update. I went out and tied the speaker wires together tight, along with the plastic connectors behind the rear pass. panel. Also one thing that stuck at as a potential problem was the rear defroster piece on the rear windshield. It has a little black plastic piece that moves a tad over the wire that runs into the windshield, so I tightened it up real good and hit it with just a drop of glue to hold it in place. I'll report back tomorrow night after ride to and from work
12-27-2005, 05:33 PM #15Member
- Sep 2005
- Pueblo, Colorado
Black- 1998 Pontiac Trans Am
Its not an f-body if it doesnt make noises and rattles all the time. lol
12-27-2005, 05:36 PM #16Senior Member
- Jul 2005
- Earth
Help: Drivers side is way lower than passenger side......
By 98TransAmWs-6 in forum Suspension and HandlingReplies: 23Last Post: 10-10-2012, 10:21 AM -
Passenger Side T Top...
By pbguy357 in forum Firebird / WS6Replies: 7Last Post: 10-15-2011, 08:26 AM -
Passenger Side Door won't open from inside?!?!?!!!
By lvbroham1 in forum General HelpReplies: 5Last Post: 01-31-2011, 06:41 PM -
Wanted: passenger side rear sail panel
By SteveCZ28 in forum Parts Wanted / TradeReplies: 3Last Post: 05-24-2010, 06:41 PM -
Passenger rear side sits lower? WTF?
By bgable in forum Suspension and HandlingReplies: 0Last Post: 09-15-2007, 01:54 PM
