Thread: 100,000 miles
    California
    100,000 miles
    I recently hit the 100,000 mile marker and was looking to freshen up my suspension. I have had the Eibach Pro kit since 10,000 miles and alse have BMR PHR, LCA's and Strut Tower Brace. Currently my ride handles well but not as it used to. It bottoms out on bumpy rides and feel somewhat "Squishy". What would be a good cure? I was thinking about replacing the bushings and maybe doing a new Shock/Spring Combo? Any suggestions on brands or parts? Thanks
    Senior Member MadSeason's Avatar
    Indiana
    when you got the lowering kit did you change your shocks? you should have, if you're still riding on the stock shocks on a lowered car you're askin for an accident. for your bushings i'd just go with the 1le setup
    Bonner Springs, KS
    99 TA
    damn your prokits have lasted that long? im impressed, mine only lasted a couple years and the right rear was sagging like 2 in lower than the left. id definately replace the springs and shocks at least
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    100k on shocks is alot. time for new ones. the compression and rebound of the shocks just isn't what it used to be. there is a rubber seal that seperates each chamber. just like a piston ring. once it wears out, the fluid seeps into both sides without compressing. the 90k on springs is getting up there as well.
  1. For Sale: 2002 Camaro Z/28 A4 Low Miles FS 28k miles Ohio
    By jmhvenom in forum Vehicles For Sale / Trade
    Last Post: 12-24-2015, 07:14 AM
  2. 99 ws6 low miles
    By sloner2 in forum Vehicles For Sale / Trade
    Last Post: 04-30-2011, 09:26 PM
  3. 06 GTO SRM M6 52k miles
    By amxguy1970 in forum Vehicles For Sale / Trade
    Last Post: 11-01-2010, 09:16 PM
  4. Wish i had this many miles!
    By 2001ws6 in forum Firebird / WS6
    Last Post: 11-29-2008, 12:10 PM
  5. 02 Ws6 8,500 miles
    By 02wssicks in forum Vehicles For Sale / Trade
    Last Post: 09-23-2006, 07:06 PM
