Results 1 to 19 of 19
    long island
    1999 Pontiac Trans AM
    What to do with 2800$
    Hey guys, i have a 99 ws6 and i have 2800$ to spend on her. I want it faster, and to sound good! what should i do? p.s. i already did intake, & exhaust.
    Retired Outlaw Sum Bitch
    Standard? Automatic?
    Cam/Tune wakes these motors up......far less than what you have to spend....if your a A4 ( I cant remember if WS6 are all standard ) then a stall will wake your ass up with the above...cam and tune for sure...
    ls1ftw tigersport14's Avatar
    Tulsa
    98 trans am
    +1 for cam and stall
    long island
    yea cam and tune sounds good. its an auto, so stall would be good.
    long island
    is it bad to do cam w/o doing heads???? If its ok whats a good cam. I want it to be noticable by performance, and sound, but not too aggresive.
    Member QKSLVR99's Avatar
    Abilene, TX
    1999 Trans Am
    depends on ehat you want. low, mid or high end torque or power. Lots of great cams out there. Also another thing to look at is do you intend to add a power added in the near future. I.E. turbo, nitrous If so look into a cam that will work well with it.
    Heads are not required but will make a huge difference down the road.
    Most sponcers have a great line up of cams just start looking and give them a call. They will be more then happy to chat with you about your setup and any questions.
    When looking for my cam I talked to a guy at Thunder Racing for almost two hours lol...
    long island
    Smile
    alright i will look into that... thanks for the help!
    Member Pete Rock98's Avatar
    Bronx NY
    1998 z28
    Quote Originally Posted by ws6talian View Post
    Did you install longtube headers?
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Don't be scared make your car a real low 11 second car. . . . . . . . . . . . . . .
    First buy a set of V-6 springs from the junkyard for the rear.
    Second install a pair of drag radials.
    Third buy a Walbro 255 fuelpump.
    Fourth install a set of AR 94 plugs.
    Fith install a quality wet nitrous plate. (175 hp jets)
    Sixth have the car tuned.
    Now you will have a mid to low 11 second car.
    That still idles bone stock,get's the same milage it always had,didn't loose ANY driveabilty,and is a sleeper.
    Abilene, TX
    1999 Trans Am
    LOL
    IMO change the walbro to racetronix pump been reading alot of thread about walbro pump over heating
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by QKSLVR View Post
    LOL
    Shit I have installed over 20 in the year and haven't had 1 issue!
    Some have issues when it comes to wiring and make bad connections by over crimping or just bad splices. Bad ground = heat
    Abilene, TX
    1999 Trans Am
    check out LS1tech few write ups on some folks having issues... one was a personal friend of mine... Head cam nitrous car in AZ 120 + degrees out side plus exhaust temps and black top road kinda funny story I laughed a bit
    Member DemonSpeed's Avatar
    Virginia
    Pewter Metallic
    1999 Trans Am
    long tubes (700 to 900) and true dual set up (got mine custom for around 500 with header install), stall (5-800), shift kit (130) and tranny cooler (50-100). These things will make you sound good and go faster. If you shop around for deals you could possibly get all these and have them installed for close to 2800 or so. Def look into a stall and shift kit, this is one of the single most effective mods you can do to an a4. I picked up 4-5 tenths at the track with a tci street fighter.
    LS6 Engine swap, Custom Predator Tune, Lid, SLP Cold Air, Ram Air H.O. Hood, Hooker Long Tubes, !Cats, 3" True Duals w/Dynomax Bullets, Performabuilt stage 2 w/3600 stall, B&M Trans. Cooler, Moser 12 Bolt w/ 3.73's
    Pics of my car
    http://community.webshots.com/user/demonspeed_ta
    Member bertt23's Avatar
    Jun 2006
    east houston
    pewter
    2002 camaro
    what are the v6 springs for?
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by bertt23 View Post
    To soften the stiff ass rear up so it will weight transfer and try to hook.
    The stock Z28 and WS6 springs are stiff as hell and by NO means are designed to aid in hooking up.
    They are about as stiff as your 2500 stock.
    Jun 2006
    east houston
    pewter
    2002 camaro
    Quote Originally Posted by LS2Tuner View Post
    actually i dont have her anymore, used to go offroading and got into some water and didnt make it out, need to change it, have the camaro and an 07 avalanche now, but it was very stiff.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    LOL
    "Racetronix" pumps ARE made by walbro...
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    I didn't even think about that until I read it. . . . . . . . . . . LOL
    From Racetronix's web site
    Custom Racetronix / Walbro pump
    Venturi feed system - Racetronix exclusive
    Red anodized billet T6 aluminum pump assembly
    Racetronix to GM Teflon wiring harness
    High-pressure non-kinking G.M. fuel tube
    Custom 30 micron filter sock
    Most of Racetronix stuff is pricey to me anyways.
    $50 more because the pump says Ractronix on it and it's red. NO Thanks you can't even see it anyways.
  1. For Sale: FS PI Vigilante 2800
    By 02blkws6 in forum Parts For Sale / Trade
    Last Post: 04-16-2010, 06:23 PM
  2. Yank 2800 Thruster Stall
    By furyev in forum Drivetrain
    Last Post: 08-07-2008, 09:47 AM
  3. Lts / 2800-2900 pills
    By 2001z in forum Parts Wanted / Trade
    Last Post: 10-24-2006, 05:01 PM
  4. Yank 2800
    By 00RedZ in forum Parts For Sale / Trade
    Last Post: 09-26-2005, 10:19 AM
  5. Hesitation at 2800 RPMs?
    By ssxcytmnt in forum General Help
    Last Post: 09-08-2005, 06:59 PM
