    Member mr_r0bert0's Avatar
    Feb 2008
    Las Vegas
    pewter
    2002 camaro z28
    window getting scratched
    Ok, so i have tint on my windows and all of a sudden my tint is gettin scratched from the inside or my door... HELP??... suggestions??
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    The felt on the door guides is worn probably. You will have to take off the door panel to see them.
    Tulsa,OK
    Quick Silver
    2002 Z06
    Yeah its the felt guides. Actually scratched the glass on my formula. Hence I have not replaced them... Glass is already ruined and I'm not putting a new window in anytime soon..
    Get it fixed quick if it has not already scratched the glass.
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
    Junior Member donman's Avatar
    Illinois
    Yellow
    2002 CETA
    I had the same problem and replaced them..They were not that expensive...
    Don
    $ 25,000 panty dropper VENOMOUS's Avatar
    Jan 2008
    Waco
    2005 Ram SRT-10 QC 8.3l
    1999 FRC Black
    About a $ 7 fix at your local G.M. dealer for the part. Take the door panel off and there are 2 per door. If you have ever locked your keys in your car, or someone was breaking in these will bend or sometimes break. NOT good to ignore because your window motor relies on the pressure against the gaskets and felt guides to keep the window on a smmoth track up and down. I 've repaired many Camaros and T/A s fiberglass door shells due to these pieces being broken or loose and the motor works the fiberglass loose around the rivets/bolts and wears a hole until the motor gets in a bind or the window is binding and tearing the fiberglass even more. CHANGE THEM NOW!!
    Senior Member
    Jacksonville, FL
    Do your scratches line up with these? http://shbox.com/1/stabilizers.jpg
    Member bryceslu's Avatar
    Chicago, IL
    00 NHRA Formula
    Mine got all scratched to hell before I caught it. And no it wasnt the inside ones, it was the "felt-guides" on the outside side of the window. spend $5 on some velcro(use soft side only) and super glue and that will fix the problem.
    There are 3 places to put the soft-velcro onto on my 94 Formy.
    After a year I JUST replaced the passenger side as they started to slide off somehow (probably becuase I didnt remove the old felt stuff first...oops)...Driver side still holding up well...and I put my windows down A LOT as I dont have/use AC. Hope this helps.
    94 m6 Formula - Sold
    2000 NHRA Formula - Always For Sale
  1. rear window froster ? wire on the rear window
    By twozs in forum General Help
    Last Post: 07-18-2012, 08:32 AM
  2. Help: scratched rims
    By gokillyourself in forum Wheels and Tires
    Last Post: 05-09-2009, 06:34 AM
  3. Camaro Window Switch/1le window/power lock delete kit
    By Marc1130 in forum Parts For Sale / Trade
    Last Post: 03-12-2007, 11:05 PM
  4. Scratched Tint and cracked door panels
    By GottaHaveLS1 in forum General Help
    Last Post: 12-05-2006, 03:17 AM
  5. Scratched T-top... can it be buffed out?
    By ScrapMaker in forum Appearance Section
    Last Post: 10-01-2006, 05:40 PM
