    Maryland
    2000 Trans Am
    Running/Turn Signal Bulbs Blowing
    Does anyone have a problem with the orange running lights burning out often? I have a 2000 T/A and have replaced them (both sides), it seems like 100 times. I keep some on hand, I have to replace them so much. Obviously somethings wrong. The flashers have both been replaced, but they still burn out. I think water is somehow getting in the lens/socket. Any suggestions and am I the only one with this problem?
    Indianapolis, IN
    All Black
    83, 87, 02 All WS6 T/As
    Yep.. they are most likely cracking in the front as well... anyway.. both mine were and water was getting in.. and blowing bulbs... so I got a new set of lenses, and one new socket (the dr side is still ok) and its been like 9 months and I haven't changed a bulb yet.
    -Geno
    1983 Black WS6 "WindCharger"
    1987 Black WS6 "WS87"
    Sold the other four f-bodies
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    did you put dielectric grease in the socket on on the bulb connector? If you don't you will keep blowing bulbs even if you replace the lenses. Just goop the stuff in. I kept blowing mine cause I kept forgetting to put the grease in.
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    to both
    Just finished with this crap two weeks ago
    Member jamessr's Avatar
    Newport News, VA
    2000 Trans AM
    Quote Originally Posted by Redphoenix1998 View Post
    +1 on that. I just bought some dielectric grease from autozone and coated the entire base with it. Water isn't an issue now for the past year.
    Tulsa,OK
    Quick Silver
    2002 Z06
    We sell upgraded gaskets that will help fix this problem.
    If your lenses are actually cracked in the front then water will get in there but the factory gaskets shrink up and stop sealing which lets water in.
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
    Houston, Texas
    2000 C5 Torch Red
    I took mine out and resealed with silicone on the front part and jbweld around the top back areas. Switched the bulbs to LED's on the front to keep them from getting the housing hot. My housing had apparently got hot and then been driven in the rain/car wash causing the piece to crack and leak.
    No issues since.
    Member QKSLVR99's Avatar
    Abilene, TX
    1999 Trans Am
    use to had problem with drives side one swapped the socket and haven't changed that bulb in almost a yr now
  1. Replies: 3
    Last Post: 12-16-2014, 02:35 AM
  2. Turn Signal Bulb CONSTANTLY blowing
    By 64MonGooSe64 in forum Camaro / SS
    Last Post: 03-10-2014, 09:05 PM
  3. Help: I keep blowing turn signal lights?
    By kool-aide in forum General Help
    Last Post: 03-29-2012, 02:56 PM
  4. Help: Turn Signal Bulbs Keep Going Out!!!!
    By cz28mdn in forum Firebird / WS6
    Last Post: 08-14-2008, 10:13 AM
